Will not idle it dies
Old May 3, 2005 | 03:49 PM
Wildwill2855's Avatar
Over the summer last year i blew a head gasket and i swaped them out and all that, changed the opti as well. i noticed that it would when warmed up idle up and down a little, i could deal with it just put it in nutral and all was fine. now its gotten baddd once it warms up the rpms want to drop and the oil drops and will die if i do not break and gas it but that only does a little. when its cold its fine it will be constant but once it heats up it will not idle in park n or drive but for a few seconds then will shut off. im hoping its something as simple as a fuel pressure regulator or something. also it takes a few seconds to start to id say sometimes its only 3 secs sometimes its closer to 6 secs or so. thanks for the help. 97z a4. i also have a tiny oil leak in the back of the intake just couldnt set right i guess dont know if this has anything to do with it. but when its warmed up it will start right up, just got to keep it revin or it will die
Old May 3, 2005 | 03:55 PM
WS Sick's Avatar
Re: Will not idle it dies
Sounds like a suspisious vacuume leak. No SES light or anything?
If youre concerned about the fuel system have you check the fuel pressure throughout the trouble area and time?
Old May 3, 2005 | 03:59 PM
yea ive got a light because of egr delete for the headers, vacuum leak, what exactly do you mean like wires or something not in the right spot or what, i mean its slowly got to where its at now it didnt happen over night thats why i was hopin thinkin a fpr or something simple?
Old May 3, 2005 | 04:49 PM
WS Sick's Avatar
The intake itself could not be sealed well to the heads, PCV system ,T/B itself, a dirty IAC or faulty one.
Do you have a scanner to look things over with realtime?
Old May 3, 2005 | 04:51 PM
no i dont
Old May 3, 2005 | 08:21 PM
ttt
Old May 5, 2005 | 04:26 PM
anyone else?
95_Z28/SS
May 20, 2015 01:23 PM
andrewcapps82
May 19, 2015 10:11 PM
beltrunner
May 17, 2015 10:18 PM
Chet1185
May 10, 2015 09:24 AM
A's 91 Z28
Jan 11, 2015 10:58 AM
