Will an LT4 bolt right into a 93 Z28?
Old Dec 1, 2005 | 07:14 PM
UtOhCop's Avatar
I was looking to buy a Third gen but i just found a 93 Z for 2K and i'm wondering if an LT4 will bolt right into the LT1's place. It's the same block right? Just different heads and intake?
Old Dec 1, 2005 | 07:19 PM
Everett's Avatar
Re: Will an LT4 bolt right into a 93 Z28?
it should bolt right up. the only difference is heads intake and a 4 bolt main compared to the 2 both main in the lt1
Shane
Old Dec 1, 2005 | 07:20 PM
Birdman7389's Avatar
Yep.....
Old Dec 1, 2005 | 07:28 PM
UtOhCop's Avatar
Will Hooker LT's bolt right up to the LT4's heads?
Old Dec 1, 2005 | 07:48 PM
96capricemgr's Avatar
Shane
There were 4 bolt LT1s too.
The next step here is for you to do a little research on the LT4 as to wether it is atall worthwhile, the answer might suprize you as it is NOWHERE near as worthwhile as the car mags would have you believe. There are lots of ways to get more power out of an LT1 DO NOT limit yourself to this overmarketted package do a lot of reading before buying even if that is what you end up buying.
Old Dec 1, 2005 | 07:57 PM
UtOhCop's Avatar
I know there are a lot of ways to get tons of power out of an LT1 but if i buy the 93 it's going to be my project car. It has 200K miles on it and instead of just rebuilding the LT1/4L60E. I plan on just swapping in a LT4 longblock/T-56 combo.
MadMav
Feb 6, 2015 11:02 PM
Bearmans
Dec 3, 2014 05:28 AM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
