Will I need a PCM tune?
Old Jan 18, 2006 | 11:25 PM
1BadZ95's Avatar
Question Will I need a PCM tune?
Hey all, hows it goin? I'm doing an engine swap on my 95 Z28. The engine I'm putting in is out of another 95 Z28 but in alot better shape. While the new engine is out I will be putting in a 510/520, 281/287, 230/236 dur @ 50deg cam, electric water pump, 1.5 rr's, and 30# injectors on top of my current mods; Hooker LT's, K&N CAI, Granatelli MAF, 52mm TB, 160 thermo, ORY, and free mods. I was wondering if my car will run correctly if at all without a PCM tune? I have a MAF Super Translater box that I may be able to tune some stuff with, but i'm not sure. Also 95's are supposed to have OBDI computers, correct? Well how come in my 95 and the one im getting the engine out of take an OBDII plug and OBDII program? I talked to a guy not to long ago and he said some 95's were half OBDI and half OBDII. What's up with this?
Thanks in advance for help!
Old Jan 18, 2006 | 11:31 PM
got8?'s Avatar
Re: Will I need a PCM tune?
I am not sure on camaros but the cars that switched body styles in 94-95 came with OBDI or OBD 1.5 it was a phase in period. I have never heard of a camaro with OBD1.5 or the hybrid model.
Old Jan 19, 2006 | 12:32 AM
jsetzer's Avatar
ALLL 95s have an OBD1 computer with an OBD2 plug. Just need a cable specific to your year. A tune is a mUST with almost any mod. It is all but required with a cam and if you swap injectors you will just waste fuel.
Tune it or don't do it.
Old Jan 19, 2006 | 02:33 PM
1BadZ95's Avatar
Well I am planning on tuning it soon but after I do these mods I might need my car for a little bit untill i have time to send the computer off to get it tuned. So I'm wondering if it will even run...
Old Jan 19, 2006 | 02:39 PM
RE AND CHERYL's Avatar
The cam you are installing is too big to run well without a tune. The added fact that you are switching injectors is an even bigger problem. If you keep the stock injectors in you MAY be able to get it fairly drivable with the MAF translator.
A better solution would be a mailorder tune with a PCM swap where you send back your PCM once you have it out.
Digital Designs's Avatar
yes it will run, but terribly rich and probably throw some codes
Old Jan 19, 2006 | 02:45 PM
1BadZ95's Avatar
Madz28.com or PCMForless.com ? I'm leaning towards madz28 for some reason. How long will it take to get it back if I send it in? Do I just tell him what I have in my car and he tunes it accordingly?
Old Jan 19, 2006 | 02:50 PM
there is an order form on madz28.com where you can specify what you need, fill it out, print it out, send it with the pcm and M-O and you will be golden
Old Jan 19, 2006 | 03:18 PM
madwolf's Avatar
http://www.madz28.com/order.php
No need to print out and send, just hit submit.
I usually mail out sent in PCMs the next day after I receive it. Takes 2-3 business days for it to get to you with rare exceptions. (like national holidays or post office screw-ups)
Old Jan 19, 2006 | 03:20 PM
Javier97Z28's Avatar
Moderator
I've never used madz28, but know people who have... but from personal experience Bryan at pcmforless did a kickass job w/ my cam tune.
Old Jan 19, 2006 | 10:18 PM
got8?'s Avatar
I just got mine back from Ion at Madz28.com and he did a great job runs like a dream.
Old Jan 24, 2006 | 01:22 AM
ram air camaro's Avatar
hey, the guys are right you will need a pcm tune definetly i have that same exact cam w/ 1.6 rockers and my car ran crappy with out tune, either pcm for less or madz28 they know what there doing just give them all your info oh also get a lt4 knock module.
not to mention you will need a torque converter upgrade for sure with that cam i'm talking from past experience.
good luck, youll like the sound of that cam not too rough and not too quit people will definetly notice you have something under that hood
Old Jan 24, 2006 | 02:35 PM
1BadZ95's Avatar
Whats the LT4 Knock Module?
Old Jan 24, 2006 | 02:58 PM
here's a pic of the lt4 knock module from shoebox website
http://shbox.com/1/lt4km.jpg
it will prevent false knock reading and there affordable so something to put on your list.
oh www.shbox.com is one of best website's online for the LT1 FBODY he is a member here visit his site
Old Jan 28, 2006 | 12:37 PM
1BadZ95's Avatar
Do you have a sound clip of your car with this cam? I would love to hear it!
