Will I need O2 extensions w/MAC Mids?
Old Jun 2, 2005 | 12:37 PM
gamecockfan04's Avatar
Just wondering what I'll Im going to need for the install and didnt know if the O2's fit good with the Macs and also will I be fine with some Felpro gaskets? Should I use RTV on them and the bolts?
Old Jun 2, 2005 | 12:44 PM
NBred94's Avatar
Re: Will I need O2 extensions w/MAC Mids?
I did not need them, I have heard of others that did, however, so there is really no way to tell until you get under there.
Old Jun 2, 2005 | 01:14 PM
stereomandan's Avatar
I originally needed one, or so I thought, on the drivers side. After taking a better look, I was able to get away without any O2 extensions, but I think I had to release on wire from it's clip behind the engine so that it would reach.
Keep in mind that I have the '94-'95 style MAC's on a '97 so my wiring might be different.
Dan
Old Jun 2, 2005 | 01:37 PM
blaze309's Avatar
I think since you have a 95 you should be ok. I have a 95 also and i'm going to be installing mac's in a few weeks and i'm hoping i don't need any. I searched and i don't think i found anyone with a 95 that needed an extension.
Old Jun 2, 2005 | 04:25 PM
Eddie95Z28's Avatar
FOUND ONE! I have a 95 single cat car and I needed one on the passenger side. Drivers side was ok but the passneger side was just a few inches short... Which really sucks since the smallest extension I could get at the time was a foot long. So I have a bunch of extra wire coiled around.
Old Jun 2, 2005 | 05:07 PM
ZMAN Z28's Avatar
Nope, they will reach
Old Jun 2, 2005 | 06:45 PM
Sandman_97Z's Avatar
mine reached fine
as for gaskets, I used the felpros dry. No leaks from them whatsoever.
Old Jun 2, 2005 | 07:48 PM
Z28Nut's Avatar
Didn't need them either.
Gaskets: Mac coppers dry. No leaks after a year. I also bolted the headers up tight 1st, then massaged the Y-pipe to fit perfectly without stressing the header bolts. Just make sure you retorque until they quit getting loose (header bolts). Mine took about 6-7 times before they quit loosening up. Also check the header/Y-pipe nuts a couple of times. My passenger side came loose after a couple of months.
GREEN3112
Feb 10, 2019 09:19 PM
FredM
Exhaust System
Feb 8, 2016 02:10 PM
Devinfoote87
Sep 4, 2015 05:52 PM
Greg88
Aug 24, 2015 07:59 AM
Z28amustangklr
Jul 18, 2015 11:05 AM
