Will this handle a 150 shot?
Old Sep 3, 2006 | 12:17 PM
AmTrans's Avatar
Eagle ESP Cast/Steel 3.750" Stroke Crankshaft
6.0" 5140 steel SIR full float rods with ARP bolts
SRP Forged Dished Pistons
Speed Pro Premium Plasma Moly Rings
Clevite 77 MS909P Main & CB663P Rod bearings
I want to throw nitro on but I don't wanna break my new build. What is the largest shot you guys would go without having a forged crank and using p series bearings? Ofcourse I would have the timing retarded and such...
Old Sep 3, 2006 | 01:26 PM
TripKidd's Avatar
Re: Will this handle a 150 shot?
a stock engine should handle a 150.
Old Sep 3, 2006 | 03:47 PM
kingman109's Avatar
as long as you take the right precautions - and dont skimp on parts
150 shot without much worry.
Old Sep 3, 2006 | 05:10 PM
grammerman's Avatar
You might want to do some research on the ring end gap. Pretty much all the piston manufacturers have you open up the gap by around .004" or so for light/moderate nitrous use. If your ring end gap is too tight and the ends butt together as the ring heats up when you're spraying it generally tears the top edge of the piston right off.
Other than that a 150 shot with those parts sounds reasonable to me. As long as you don't lean it out Make sure you have ample fuel pump capacity to maintain pressure at wide open throttle.
Later, Michael
Old Sep 3, 2006 | 05:41 PM
OBE1 95Z28's Avatar
Properly tuned you shouldn't have any issues.
Old Sep 3, 2006 | 06:33 PM
396D1SS's Avatar
a 200 shot would be safe for that combo
Old Sep 3, 2006 | 06:49 PM
AmTrans's Avatar
I have an awesome inline fuel pump and 42# injectors. I will buy a mallory unit or something like that.
The engine is already assembled but not in the car, how hard is it to adjust the ring gap?
Old Sep 3, 2006 | 07:02 PM
Robs97Z28's Avatar
you can pull one piston at a time or tear down the whole block. It would much earier to do it this way. you have to file and fit each ring to each cylinder and there are 2 per cylinder.
Old Sep 3, 2006 | 07:03 PM
marshall93z's Avatar
Why the dished pistons? What compression ratio you shooting for?
Old Sep 3, 2006 | 07:06 PM
AmTrans's Avatar
It was my idiot builder chose them. I didn't want dished, he seemed to think the CR woulda been too high with flat-top. I bought this engine already assembled at a good price. He says the CR is 10.6:1
Old Sep 3, 2006 | 09:43 PM
YZF/LS1 Freak's Avatar
Yep just get a good fuel pump...
Old Sep 4, 2006 | 12:31 AM
CamaroRacing12's Avatar
i wouldnt go more then 150 shot but hey thats just me
Old Sep 4, 2006 | 06:29 PM
mattybz28's Avatar
Werd.
Don't forget to go with colder plugs.
LT14LIFE
Nov 15, 2015 06:22 PM
form94
Sep 23, 2015 07:30 AM
Sep 17, 2015 11:53 AM
NewsBot
Sep 15, 2015 11:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
