Will a Cloyes timing set fit my 95z?
Old Nov 7, 2008 | 09:14 PM
Projectcam94's Avatar
Question Will a Cloyes timing set fit my 95z?
I read somewhere that i would need a different timing cover? But im not sure. Im putting in a cc503 , gmp 1.6 rr, cc hardened push rods, beehive springs.
But I also want to change the stock timing chain. If this does need a different cover is there anything that will fit right in?
Old Nov 7, 2008 | 09:27 PM
bombebomb's Avatar
im not aware of an aftermarket cover for the LT1, you may need to clearence it however.
Old Nov 7, 2008 | 10:08 PM
You would also have to run an electric water pump.
Old Nov 7, 2008 | 10:11 PM
Hmm what a bout a lt4 hd timing set? I dont feel like buying a electric wp
Old Nov 7, 2008 | 11:17 PM
You could use that. A stock set will also work.
Old Nov 8, 2008 | 12:20 AM
LaredoZ28's Avatar
A few of my friends put Cloyes timing sets in their cars and had no problem. I put the Comp Cam in mine when i had my cam put in. No problems with that one either.
Old Nov 8, 2008 | 01:22 AM
henryz28's Avatar
The cloyes and the electric water pump are not much more. I paid less than $100 for my cloyes double roller set. A csr ewp is $180 shiped on ebay. All I had to do was have the crank shaft sensor tuned out, install the ewp and freeze plug the water pump hole in the cover. I did no clearance on the cover. The lt4 extreme duty is $250. The cloyes double chain is stronger and you will gain about 10hp at the tires from the ewp.
Old Nov 8, 2008 | 01:34 AM
henryz28's Avatar
Here is the chain I am running.
http://cgi.ebay.com/ebaymotors/Cloye...QQcmdZViewItem
Old Nov 8, 2008 | 06:42 AM
CrashnBurn's Avatar
i actually have the cloyes double roller set on my car. You need/i used an ewp, 95'-97' timing cover{might need minor clearancing} w/crank position sensor(wont be hooked up just fills hole in cover), 95'-97' cam(dowel pin is different), and a 95'-97' opti
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
Dec 4, 2014 11:56 AM
