Will CC987 springs work with Trick flows?
Old Apr 7, 2005 | 12:04 AM
ProchargedLT1's Avatar
Like title say. Will the CC987 springs work on the Trick Flow heads?
Old Apr 7, 2005 | 12:12 AM
SStrokerAce's Avatar
Re: Will CC987 springs work with Trick flows?
Why? Cause they are cheap....
Bret
Old Apr 7, 2005 | 12:17 AM
No because I already have a set.
Old Apr 7, 2005 | 12:18 AM
Well that sucks.... I've never been a fan of them. Just can't do a whole lot with them as a cam guy....
Bret
Old Apr 7, 2005 | 12:25 AM
Really?
My cam is only a .535/.554 lift with 1.6RR
Old Apr 7, 2005 | 01:01 AM
Well it will work with that low of lift.... If you set them up at 1.750 and don't run more than that lift ever with them you will be cool on most things if you keep the RPM down to below 6200rpm.
Bret
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
