Will this cam work fine in a factory shortblock?
Old Nov 12, 2006 | 11:02 AM
CDN WS6's Avatar
Will this cam work fine in a factory longblock?
I bought the following cam off a fellow board member. The specs are as follows;
224/230 .570/.570 112
Will I have enough piston to valve clearence when running comp 1.6 nsa rr's with this cam?
Tyler
Old Nov 12, 2006 | 04:22 PM
RUDEDOG's Avatar
PTV clearance should be fine with that cam with 1.6 rockers if pistons are stock.
Old Nov 12, 2006 | 04:29 PM
CDN WS6's Avatar
everything is stock (heads have never been off). Thanks, just wanted to make sure before I put it in.
Old Nov 12, 2006 | 04:34 PM
sandman63's Avatar
wow thats a pretty big cam!
Old Nov 12, 2006 | 05:01 PM
FryedClutch's Avatar
just out of curiosity how is that BIG??
its a mild cam with decently high lift
actually if i had to guess id think it was one of the new comp XFI cams
but that should be a very good cam and give you decent power and maintain streetability excelent choice IMO
Old Nov 12, 2006 | 05:37 PM
wrd1972's Avatar
Agreed, from mild to insane this cam is right down the middle.
Old Nov 12, 2006 | 06:37 PM
sandman63's Avatar
Sorry, i meant the lift. Yeah i know its not huge, but its a decent sized cam.
Old Nov 12, 2006 | 06:52 PM
CDN WS6's Avatar
This cam was Jason Shorts. He put down 358rwhp/362rwtq on stock unported heads.
Old Nov 12, 2006 | 10:42 PM
sandman63's Avatar
CDN WS6 by any chance were you at Gimli the second last weekend? I think around the 23 of sept?
liamcg97
Nov 25, 2019 05:55 PM
Rod Bender
Jan 1, 2015 03:18 PM
Snoman73
Nov 17, 2014 07:22 PM
Rino1313
Jul 19, 2002 04:31 PM
Rino1313
Jul 18, 2002 05:16 PM
