Will A/C delete throw any codes???
Old Feb 22, 2008 | 02:43 PM
95firehawk's Avatar
Since I never use it and the fact that its becoming more and more of a track car anyway I was wondering if deleting the A/C would throw any engine codes? I tried doing a search and it was mentioned but never really confirmed. Also is it necessary to fill the gaps between the shroud and the radiator after you remove the condensor? I tried to read upon this as well and from what I could tell it was 50/50 on whether or not to do this (or if there was any gaps left at all.) Any info would be helpful. Thanks.
Old Feb 22, 2008 | 02:54 PM
a4z28's Avatar
On my 95z it didny show any codes. But it might show if you turn the ac on trying to engage the clutch, then it might show something.
Javier97Z28's Avatar
Moderator
No as far as codes...
And i'm not sure what most guys do when they remove the condenser.. not sure if there' airflow issues that needed to be tended to.
Old Feb 22, 2008 | 02:57 PM
rcantrellz28's Avatar
Didnt throw any codes on mine , my car is a 95.
Old Feb 22, 2008 | 03:03 PM
95firehawk's Avatar
Thanks for the quick replies. Tax return money is burning a hole in the pocket (lol) and I want to get ready for the race season. Just want to make sure that I've got my bases covered before I start on any work. Guess I'll try it and find out with the !condensor. Can't be too hard to seal it up if it poses any problems. Someone not to long ago posted pics up of a custom setup that sealed the radiator but I couldn't find it. Hopefully he finds his way here. Thanks again.
Old Feb 22, 2008 | 03:47 PM
White Lightning's Avatar
it will throw a code, but not turn the light on
Gtpguy
Jan 26, 2015 04:50 PM
Deadbolt24
Jan 19, 2015 01:29 PM
cmdeshon
Dec 27, 2014 10:06 AM
91Bird305
Aug 5, 2002 01:39 PM
