Will balancing DS fix vibration?
Old Jul 28, 2004 | 10:15 AM
raxxus's Avatar
I'm about to have my girl run up to ft wayne and have my ds balanced ( I can't b/c of work ), and I was just wondering if that would fix the horrible vibration I feel in it?
Also, where could I order online to get a replacement filter for my moroso cold air? It's pretty banged up and I'd like to replace it.
Old Jul 28, 2004 | 11:12 AM
Heatmaker's Avatar
Advanced Member
Re: Will balancing DS fix vibration?
IF you have an unblanaced DS that can cause vibration... so yeah... unless it's due to a more serious unforseen problem in your Drivetrain.
You should be able to get the Filter for the Moroso at AUtozone Pepboys ETC... it's just a regular K&N filter... all you need is the Part number to order it from them.
Old Jul 28, 2004 | 12:25 PM
Pasky's Avatar
Wheel bearings, tire balance, driveshaft balance....they all play a part in vibrations, try to check them all out first.
Old Jul 28, 2004 | 12:47 PM
raxxus's Avatar
I work at a shop, and almost everything else has been checked and fixed! All the guys here point to the DS as the main culprit also. We'll see, I'm taking it out tomorrow!
Old Jul 28, 2004 | 12:48 PM
Pasky's Avatar
Im not sure about fourthgen steel driveshafts, but on thirdgens, which I think are the same, they were only balanced up to 85 mph.
Old Jul 28, 2004 | 01:41 PM
GREGG 97Z's Avatar
I'm pretty sure GM continued with that great idea for the 4th gen steel ds. My original ds used to start vibrating real bad after 80mph, it killed my stock rear after only 25k miles. Makes sense to only balance a driveshaft to 85mph on a car with a 150 mph speedo which is more than capable of reaching that speed. GM engineers
Anyway, I wouldnt bother messing with trying to balance the stock ds, just replace it with an LS1 ds, you can get one for $100-$150 used. Many people have tried balancing the steel one only to still have vibration problems with it. The LS1 ds is much lighter and better balanced.
Old Jul 28, 2004 | 02:01 PM
quicksilver97ta's Avatar
Whatever you do, have them check for run-out. My LS1 drive shaft had the ends welded off-center from GM. Once welded on-center the balance was perfect. The factory weights were no longer needed.
Old Jul 28, 2004 | 03:59 PM
97FormulaWS-6's Avatar
It can help, but it can screw things up worse... make sure they are balancing the DS at a high enough RPM. One local shop only does it to 3600rpms, which isn't fast enough.
I fought a vib problem for a long time, even a LS1 shaft didn't fix it; so be forewarned, it's not a fix-all.
The only thing that DID fix it was a NEW driveshaft made specially for me; Denny's Nitrous Ready.
Old Jul 28, 2004 | 04:14 PM
Heatmaker's Avatar
Advanced Member
Did you guys already forget...??? THe steal driveshafts always had bad Vibro problems... remember the GM recall...??? THat's why they decided to go aluminum in the LS-1.
Old Jul 28, 2004 | 06:48 PM
Mtrhds94Z's Avatar
Try to find a 1LE shaft[ a lot better than an LS1]
Old Jul 28, 2004 | 07:46 PM
Ellis's Avatar
I've had a couple of 3rd gens. The last one I put a 3rd gen Al 1LE shaft in. There was no vibration issue, but the car was a 1LE and was missing the shaft, so I thought it should have the correct one.
Well, after some tool hit me on I-95, I picked up my '97 Formy. I went ahead and put the 3rd gen 1LE DS into her. What I noticed on this swap was that the 4th gen DS had a vibration damper on it from the factory. None of the 3rd gens I had were equipped with one of these. So the engineers must have done something about the vibration issue. The bean counters don't let them add parts for fun.
Anyway, just thought I'd throw that out there.
BigWil
Mar 29, 2015 12:24 PM
Rde Bandit
Mar 21, 2015 10:17 PM
squarehead
Nov 21, 2014 08:02 PM
MislMan
Jul 19, 2002 11:41 AM
