Will 96-97 Pacesetter LT's w/emissions work on a 95?
Old Feb 17, 2007 | 05:23 PM
KillerTA's Avatar
Will they fit a 95 if I block off the emissions control stuff? Is this a good or bad idea?
Old Feb 17, 2007 | 05:27 PM
2000GTP's Avatar
The headers themselves will still work. If you aren't going to use the emissions equipment, then you won't have to worry about that stuff hooking up correctly.
Old Feb 17, 2007 | 06:12 PM
Makaveli's Avatar
only difference is the thread size on the AIR outlets, and maybe the location of the EGR hookup, but i might be wrong on that. I am positive the AIR outlets are of a different thread size, but if you are not using emissions, then you are in the clear!
Ringmaster72
Dec 12, 2017 10:12 PM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
