Will 30# svo injectors be good for xe 230/236, ported heads, occasional n2o?
Old Nov 17, 2003 | 11:00 PM
Aeromaks's Avatar
Going to drop in Xe 230/236 cam with ported stock heads, with 1.6rr etc.....
I am planning on spraying between 75-125 every once in a while eventually in the future....
Will the 30# SVO injectors be good?
Old Nov 17, 2003 | 11:08 PM
93Z286Speed's Avatar
i have the same basic question i was thinking of going with the same basic thing with mabey a 355 and as big as a 200 shot (mabey smaller) probly a 58mm tb aswell! id love to know if a set of 30# inj's would be good
(Sorry to steal your thunder, just seemed like an appropriate place to post )
Old Nov 17, 2003 | 11:11 PM
madwolf's Avatar
Yes, they'll be good. Just make sure to get Ford SVOs. (as opposed to Accels)
Old Nov 18, 2003 | 12:06 AM
nitropatch's Avatar
our stock 24lb holds 425 hp so i think you will be fine
Old Nov 18, 2003 | 12:38 AM
Aeromaks's Avatar
I have a 93, so i think the injectors were slightly smaller, 22's i believe.
Old Nov 18, 2003 | 12:39 AM
madwolf's Avatar
Yep, all 92 and 93 LT1s had 22 lb/hr injectors. Including Vettes.
Old Nov 18, 2003 | 08:29 AM
LT4POWR's Avatar
wet or dry n2o shot?
Old Nov 18, 2003 | 01:37 PM
llafro's Avatar
On the stock fuel pressure with 30lb injectors, I am running 75-80 % duty cycle at 6400 RPM. The stock fuel pump keeps up with it, but just barely. With nitrous, I would think you'd want to go with a wet system and upgrade the fuel pump to an aftermarket unit that won't run out when you least expect it.
oldschool
Feb 9, 2016 09:21 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
