Will 18's make me slower?
Old Jun 9, 2003 | 03:08 PM
SWINGRRR's Avatar
Going to 17's in the front and 18's in the back. Will this hurt me?
Old Jun 9, 2003 | 03:56 PM
FTC's Avatar
FTC
when i went from aluminum 17x9.5 budniks to chrome 18x9.5 y2k vette rims it was a bit more sluggish off the line. but i really liked the look of the 18s. now im ready to go faster again
Old Jun 9, 2003 | 04:31 PM
Will84's Avatar
Re: Will 18's make me slower?
The problem is not with the actual 18" wheels. It's when you put the real low profile tires on there that you have a problem. Find a tire with enough side wall and you should be fine.
Old Jun 9, 2003 | 05:13 PM
SWINGRRR's Avatar
Sweet. Thnx for the reply's. I'll be sending the MO off in the am.
Old Jun 9, 2003 | 11:59 PM
CrippleFightin's Avatar
Keep in mind they are heavier too. That'll slow you down a little as well.
Old Jun 10, 2003 | 01:42 AM
RyanMacZ28's Avatar
You would have to find out how much more they weigh over stock. Each pound you add to your tires adds 5 lbs of rotational mass, so, if they weigh 5 lbs more per tire, thats 50 lbs of rotational mass right there
Old Jun 10, 2003 | 02:15 AM
Jcb890's Avatar
u need to get the speedo reprogrammed somehow too right? now what size tires came on the car stock? i have 245/50/16, is that the stock tire size? should i get the speedo reprogrammed? im pretty sure this is stock size and my speedo is fine, im just wondering.
thanks,
jake
Old Jun 10, 2003 | 02:33 AM
RyanMacZ28's Avatar
You are all set with your tires, no need to get the speedo reprogrammed. But for the guy going huge in the back, going to be a little slower, and need to reprogram the speedo for them.
Old Jun 10, 2003 | 10:55 AM
pu12en12g's Avatar
No, you won't be noticably slower.
Old Jun 10, 2003 | 11:09 AM
FireAm94's Avatar
Call me crazy but I could "feel" the difference when I went from 16" salad shooters to 17x10 O.Z. Racing....the wheels are a decent bit heavier....but there is also alot more rubber that adds to the weight difference.
Joe
F'n1996Z28SS
Aug 23, 2023 11:19 PM
AdsoYo
May 2, 2018 03:21 AM
siguy
Nov 27, 2014 10:07 AM
