Will 1.7RRs drop my mpg?
Old Jul 24, 2004 | 04:59 PM
Robert95z's Avatar
Im currently getting about 230 to a tank, and thats about as low as I want it to go untill I buy another vehicle. But of course, I want more power out of my NA car.
So just curious if anyone has experinced MPG loss with 1.7 or even 1.6 roller rockers
Old Jul 24, 2004 | 05:57 PM
disco192's Avatar
Re: Will 1.7RRs drop my mpg?
230 per tank? Sounds like something is wrong. I get 260+ to a tank right now and im running open headers without o2 sensors cc306 cam and ported heads....
I doubt that 1.7 will drop gas mileage....
Im actually thinking about going 1.6 on my exhaust and 1.7 on my intake. If you want to, we could split that set of 1.7.....
-Stu
Old Jul 24, 2004 | 05:59 PM
Robert95z's Avatar
I'd be down if i knew 1.7/1.6 combo made more HP, but im not sure if it would, it probably varies car to car.
As for my mpg, im not sure, auto with 3.73s i thought that was fairly normal.
Old Jul 24, 2004 | 07:06 PM
Ryan's LT1's Avatar
230 is normal for an A4 with 3.73's. Can't help you with the 1.7's though.
Old Jul 24, 2004 | 08:04 PM
Somnambulist's Avatar
1.7's will just keep your valves open a slight bit longer than with stock or 1.6's. The effect on gas mileage is extremely minimal...
Old Jul 25, 2004 | 12:08 AM
eagleknight97's Avatar
230 with those gears in an auto is actually pretty good. Personally, im only getting like 210 with 3.23's, but I have something wrong. But lots of people ive seen are getting around that with just 3.23's, so I think you are ahead of the curve.
Old Jul 25, 2004 | 12:54 AM
ishz28's Avatar
I wish I was getting 230 a tank. After the cam (227) engine work and 3.73's in my A4 I get 200-220 town/ highway/ 180 town. Maybe it'll change, if I ever get a comp. tune?
Old Jul 25, 2004 | 12:56 AM
BoostCrzy's Avatar
actually they wont be open any longer(duration stays the same), but they will open further.....
Old Jul 25, 2004 | 10:16 AM
stereomandan's Avatar
The valves won't be open longer, but the overlap area will be larger. The 1.7 RR's will make the slope of the ramps steeper, so the area where both valves are open will be greater. This will cause more scavenging, which can be good for power, but has negative effects on gas milage. I doubt it would be enough to be very noticable. Now, changing duration without changing the LSA (lobe seperation angle)is where you start to loose significant gas milage.
Dan
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
kandied91z
Sep 30, 2015 11:43 PM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
