Wierd Noise, Help!!
Old Apr 14, 2005 | 11:04 AM
Z28Horn's Avatar
Wierd Noise, Help!!
Hey guys, i was driving my car yesterday beating on it a little bit, then i got onto the main drag doing about 45mph. I get this random noise, kinda sounds like your throwing a empty pop can out the window, i dont have a posi, i have a power trax locker, real decent.. Anyway, it only happens when im coming to a stop, and it happend once, while i was cruising at 45. Any ideas?? Mods are in sig. I do have a header leak on my drivers side, w/ copper gaskets. Could it be the copper gaskets rattling a little bit? Any help would be appreciated. Thank you.
Zach Horn
A.C.S. Inc.
Old Apr 14, 2005 | 11:16 AM
nonojoe66's Avatar
Re: Wierd Noise, Help!!
could be your brake pads shifting in the caliper a little, wont hurt anything if thats it. i think they make a glue for it or somthing, mine used to do that but it went away when i changed the pads
Old Apr 14, 2005 | 11:25 AM
Z28Horn's Avatar
Really, the same noise, Ive never heard this before. ting ting, its kinda loud, and embarrassing. Ill check the calipers, otherwise im changing them damn copper gaskets for the felpro 1406's today.
Old Apr 15, 2005 | 10:43 AM
Z28Horn's Avatar
Brakes are fine, does it when i rev it up sometimes. It seems to make that noise more when im coming to a stop, ive looked for wrenches, or other tools in my engine bay? Could it be my copper header gaskets? They do leak.
Thanks guys.
Zach Horn
Old Apr 15, 2005 | 01:37 PM
camaro777tom's Avatar
Yeah, would it be backpressure related, since it is happening when you are decellerating?
Old Apr 15, 2005 | 02:33 PM
Z28Horn's Avatar
It happens every so often when im excellerating as well. Im clueless, i will be re-doing the header gaskets today. I will double up the felpros, see if this helps, like i said, its random ting ting. Any other suggestions??
Zach Horn
Old Apr 15, 2005 | 02:37 PM
White_96_SS's Avatar
I dont think I would double up the gaskets(never heard of that before..??)..just do the gasket change and make sure ALL the header bolts are tight..see if it helps..and make sure after a couple hundred miles to recheck the header bolts..
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
GT what?
Jul 14, 2015 10:17 PM
colts0455
Jul 7, 2015 07:19 PM
