Wierd idle problem...
Old May 4, 2003 | 11:26 PM
96z's Avatar
96z
I got the stroker together and the idle doesnt seem to want to come down. Right now it idles between 1500-2000 rpms and my program has it set for 1000. The TB blades are completely closed...anyone have any ideas besides a lazy IAC, anyway to test it?
Old May 4, 2003 | 11:28 PM
Rodrigues's Avatar
it obviously sounds like you have a vacuum leak! spray some starter fluid around possible leak areas and listen for change in idle rpm's.
Old May 4, 2003 | 11:30 PM
turbo_Z's Avatar
could be a vacuum leak. what does it say on a scanner? i know my tach reads about 300 high.
Old May 4, 2003 | 11:34 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
if the butterflys are basically closed and your idleing at 1500-2000 then its getting air somewhere else..... check the vacuum
Old May 4, 2003 | 11:46 PM
96z's Avatar
96z
I forgot all about that, Ill have to check that out tommorow than...
Old May 5, 2003 | 01:24 AM
camaro6's Avatar
My car is doing the same thing. Idleing high between 1500 and 2000. I'll have to check the vacume tomorrow.
Old May 5, 2003 | 01:43 PM
96z's Avatar
96z
Hmm...if you figure it out could you let me know what you find out?
Old May 5, 2003 | 02:41 PM
Farfrominnocent's Avatar
what is a vacuum leak
and could that happen on a regular lt1 engine?
thanks
Old May 5, 2003 | 04:04 PM
96z's Avatar
96z
Originally posted by ACA Performance
Just an idea, but i assume that you got rid of egr with the stroker, did you plug the port on the intake for that?
Yeah that got plugged up last year when the LT's went in...
68camaroboltz
Oct 5, 2015 01:46 PM
Double aught
Oct 2, 2015 11:29 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
