wich injectors and tb
all right guys im planning on running a LT4 hotcam kit, with ported heads, and ahving my manifold ported to whatever size tb i get. Also my list of upgrades include : Intake, headers, full exhaust, fan switches, 160* stat, and after i get the cam/heads installed im going to have it tuned at RPm so my questions to you... what size injectors and what size TB should i get to run on this setup?
-steven
-steven
Re: wich injectors and tb
Originally Posted by sean1997ws6
should be fine with a set of 30lb injectors.
I've used the hotcam before and it's a nice overall cam. The 30# injectors should be fine and a 52mm tb is good, you don't even need to port the intake for it, might want to port match the intake to the heads, though.
Doesn't seem like you'd see any significant gains by going bigger with the TB or injectors with a small cam and ported LT1s. I'd have it dynoed with the stockers and see if it compares with others who have gone bigger before going bigger. JMHO
Originally Posted by ROOSTER93V8
Your stock injectors should actually be plenty for that application.
A 52mm is good for about 6rwhp.
autoxr166
Sep 25, 2015 04:21 PM
