Wich Carsound cat?
Hey guys, im about to install my Jet Hot LT's, and im having a custom y-pipe made for it. Does anyone know wich carsound cat(s) i should use? I have a 97 Z28. Thx
Hhhmm ok. Is the correct part number? 94119 that is the 3" with AIR fittings, since you said a single one. Im guessing you are recomending putting it directly after the y-pipe instead of having 2 in the y-pipe?
Ok thx, do you happen to have any pics of your setup? And also do you know wich O2 sims i will need? The flat or square connector?
Edit: not to question you but, i still have all emissions including AIR, are you sure i dont need one with AIR fittings? Thx Tyler
Sep 11, 2015 09:44 AM
