Why no lope?
Why no lope?
I have been building my car for a while now. I have so much stuff done to it. In a nut shell it has the 2050 compucam in it. I don't really know the differance between that and like the hotcam that I hear about? the problem is I can't really hear that much of a lope? I have shorty headers but the it all runs into one pipe then into the same muffler then out. Would that kill the sound? It kinda mad since to me, but I'm been called crazy before too?
Re: Why no lope?
I just love the sound of the lope!! From what I gather it has a 490 lift, and with the 1.6rr it will make it 510. Shouldn't it be lopping? Is it lift or duration that gives it the lope?
Re: Why no lope?
The duration matters somewhat, but its mostly the lobe separation.
I checked out that cam, it looks like its on a 112deg lsa. At that lsa there should definately be a destinctive lope at idle. Try to get some sound clips up.
Re: Why no lope?
Originally Posted by shoebox
I have a 224/230 on a 114 LSA and it does not lope all that much.
Mike
Re: Why no lope?
The hot cam w/ 1.6 rockers and SLP shorties has a slight lope in my car @ 900rpm. I also surges slightly at low rpm in 1st and 2nd gear. This surge can be annoying at times. If yours does not have low rpm cam surge and makes good overall power, you should be happy. Don't get me wrong I like the power of the hot cam and it provides improved torque and power to 6000+. Tell everyone your car is stock then blow their doors off !
