Why are my left side taillights brighter than my right?
Old Feb 5, 2004 | 11:19 PM
KillerTA's Avatar
All my bulbs are good. Do I need a new taillight harness?
Is a harness hard to put in?
Old Feb 5, 2004 | 11:35 PM
Brundle's Avatar
put new ones in n e ways. the bulbs may still be good but i find sometimes the older ones won't shine quite as bright as the newest ones
Old Feb 6, 2004 | 06:09 AM
slopokrodrigez's Avatar
If you don't want to buy new ones, try swapping side to side. The problem will follow one of them. Then buy the ones you need. It's not your harness.
Old Feb 6, 2004 | 07:59 AM
Fastbird93's Avatar
There's actually a very distinct possibility of it being in the wiring. Keep it simple. Check the bulbs, and if that doesn't do anything, check the wires and sockets. DO NOT BUY SOCKETS FROM THE DEALERSHIP!!!! They'll charge like $50 each, when you can get them at a Pep Boys for like $4.00 each.
Old Feb 6, 2004 | 09:44 AM
JohnD's Avatar
Probably one bulb is older than the other. Vaporized filament darkens the bulb over time. That's why when I replace one bulb, I always do the one on the opposite side at the same time, that way they age together. Also the one that didn't go out will be the one that is next to go out if you leave it in. Save the working old one for an emergency spare.
JohnD's Avatar
Old Feb 6, 2004 | 12:00 PM
1996GTP's Avatar
I have the exact same problem and traced it to a bad connection inside the socket. Now I just need to get around to replacing it.
Old Feb 6, 2004 | 05:24 PM
KillerTA's Avatar
I'm going to buy a wiring harnes with all the sockets off ebay, so hopefully that'll fix it.
CheckOutMyRoost
May 31, 2015 10:40 AM
karguy16
Mar 6, 2015 01:31 AM
Jazsun
Dec 29, 2014 12:14 PM
Dreamaster
Jul 17, 2002 04:36 PM
