why is my antifreeze brown and chunky lol
Old May 2, 2004 | 04:49 PM
  #16
GreenDemon's Avatar
Originally posted by Cmr0z28
AFAIK, ALL LT1's came with orange dex-cool from the factory. Mixing green antifreeze with dex-cool is a no-no.:blah:
Had a 96 before this car. 96 was the first year for the orange stuff in the camaros.
Old May 2, 2004 | 05:03 PM
  #17
Tim240z's Avatar
I also recently drained my coolant. I put in some flush additive and distilled water....ran it for 30 minutes, then drained it again. Filled it with distilled water, ran it again to temp and drained it. Then I filled it with ~ 50/50 distilled water and 'the orange stuff' and purged the system. My coolant is also still dirty brown. No coolant in the oil and the system appears to be keeping the car cool. I guess it needs a power flush or something?
Old May 2, 2004 | 05:18 PM
  #18
GreenDemon's Avatar
It appears you're not the only one.
http://www.consumeraffairs.com/autom...m_dexcool.html
My only thoughts on this is that you should run it with just straight water for a warmup cycle to try to remove any more sludge that may still be in the block. After that I would fill it back up with dexcool and try to get it as topped off as possible because I don't think dexcool really likes air very much. When I had my 96 I noticed there was kind of a brown caking on the dipstick, but I just cleaned it off and never had any problems. I guess depending on your environment, dexcool may not be very good at all, and will last significantly less than the green stuff that has been in use for who knows how long.
Old May 3, 2004 | 01:07 AM
  #19
93midnightta's Avatar
as the others have said this is not correct. my 93 definately came with the standard green antifreeze.
Old May 3, 2004 | 02:06 AM
  #20
Spinner's Avatar
Dex sucks. Drain it and fill up with green
Old May 3, 2004 | 03:20 AM
  #21
Ryan's LT1's Avatar
^ What he said.
Old May 3, 2004 | 07:46 AM
  #22
HBHRacing's Avatar
I like Dex-cool. It is more friendly then the old antifreeze if you treat it right
Old May 13, 2004 | 07:37 PM
  #23
manoso84's Avatar
if your car came with dexcool then use dexcool or read the owners manual. the dexcool wont corrode the aluminum block and parts like the green stuff does. I dont know if your block is aluminum since its lt1
Old May 13, 2004 | 08:03 PM
  #24
bdc95ta's Avatar
like others have said already...as generaly rule of thumb all makes and models in 96+ got dex. before green. I have a 95 ta and it's green. Dex. is supposed to be better though it's supposed to last a lot longer than the green stuff.
-b
Old May 13, 2004 | 08:17 PM
  #25
R8E1D's Avatar
So what do you do if you have a 96 and the green stuff is in it? Flush and refill with DEX?
Old May 13, 2004 | 08:27 PM
  #26
Spinner's Avatar
Flush it yearly and refill with... GREEN
Old May 13, 2004 | 08:28 PM
  #27
bdc95ta's Avatar
^ yup what he said, thanks spinner.
Old May 13, 2004 | 08:39 PM
  #28
manoso84's Avatar
Post
read your owners manual, it should tell you what to use
Old May 15, 2004 | 08:28 AM
  #29
94DROPTOPZ28's Avatar
Hmmm when I had bought my 94Z new it came with Dex Cool....
93 RedBird
Nov 15, 2015 08:24 AM
Bxlt1
Sep 29, 2015 03:18 PM
Bxlt1
Sep 17, 2015 08:31 AM
Pwilson59
Sep 3, 2015 08:47 PM
