Why dont Stock LT1's or LS1's come with 6" rods??
Old Apr 20, 2004 | 04:17 PM
ZDriver96's Avatar
Why dont these engines come with 6 inch rods stock? There seems to be no price difference in aftermarket rods between 5.7 and 6 inch. So if most people recommend going 6inch when you do a rebuild then why dont they come stock with 6 inch.
We have high compression stock engines and they suck for superchargering which likes the 5.7 rods. So why not have 6" cuz other stuff will blow before the rod will on a stock engine..
Old Apr 20, 2004 | 04:18 PM
WS Sick's Avatar
Emissions and tooling have alot to do with it.
Old Apr 20, 2004 | 04:27 PM
97WS6SCharged's Avatar
GM runs the same basic rotating assembly in all their v8 motors. They buy 5.7" rods by the thousands. It wouldn't make sense to stick 6" rods in their Fbody/vette motors and 5.7" rods in their trucks/vans/etc... Plus when you change the rods, you have to change the pistons and a whole bunch of other crap. So they keep it simple by using the same rods in all their v8 applications.
Old Apr 20, 2004 | 04:57 PM
ZDriver96's Avatar
ah thanks guys... well damn that... Going 6 inch...
Old Apr 20, 2004 | 04:58 PM
Make it a 383.
Old Apr 20, 2004 | 05:20 PM
ZDriver96's Avatar
i just dont want to mess with the stuff anymore... forged internals so i'll beable to spray it in the future if i feel the need. or get bored with it. I dont want to deal with any unforseen issues or costs
Old Apr 20, 2004 | 05:45 PM
med_reject's Avatar
I thought standard length was 7.2"??
Old Apr 20, 2004 | 06:12 PM
ZDriver96's Avatar
no.
Old Apr 20, 2004 | 07:40 PM
med_reject's Avatar
what are these guys talking about??
http://web.camaross.com/forums/showt...shrods+AND+lt1
http://web.camaross.com/forums/showt...6&goto=newpost
http://web.camaross.com/forums/showt...61#post1750161
Old Apr 20, 2004 | 08:13 PM
96speed's Avatar
Pushrods.
This thread is about connecting rods. Connecting rods connect the piston to the crankshaft.
Ryan
Old Apr 20, 2004 | 08:54 PM
med_reject's Avatar
hahhahahah, ok. I was a little worried cuz i 'm buying 7.2" pushrods. anyway, take care, and good luck with the build
Old Apr 21, 2004 | 06:41 PM
arnie's Avatar
Re: Why dont Stock LT1's or LS1's come with 6" rods??
Short of adding a tall deck block into the mix, which would make such a swap cost prohibitive, the longer rod requires the pin be positioned higher on the piston. From the oem's perspective, the potential sacrifice of longevity/durability, of and from the use of this shorter skirted piston, makes it an unsound corporate financial decision.
Old Apr 21, 2004 | 09:26 PM
96capricemgr's Avatar
Just to throw some confusion into the mix.
The L99 which was the base motor in the Caprice during the LT1 years is basically a smaller stroke smaller bore LT1, and it used 5.94" rods. Displacement was 265 or 4.3l whichever you prefer, and yes it was the same bore and stroke as the original SBC from the '50s.
Old Apr 22, 2004 | 07:20 PM
arnie's Avatar
Originally posted by 96capricemgr
Just to throw some confusion into the mix....
B4 I personally could reply with any degree of credibility, (if indeed I have any) I'd need a reliable/accurate source to obtain the L99 block deck dimension, along with the piston compression hgt. However, to take a blind shot at it, IF, by chance, that block has same deck dimension as an LT1 block, figuring in the rod length dimension noted by Dwayne, would suggest the piston compression hgt. is the same as the oem Lt1 piston.
Old Apr 22, 2004 | 08:14 PM
speedmiser's Avatar
You might want to consider rods shorter than 6" if you plan on spraying. You dont give up much with 5.7s or 5.85s, and you get a thicker piston deck and lower pin height.
