Why does my oil pressure drop slightly at 5k and then back to normal???
Old May 3, 2003 | 02:23 PM
95LT1Z28's Avatar
Lightbulb Why does my oil pressure drop slightly at 5k and then back to normal???
Just got done doing my cam install and computer tuning from PCMforless. I got on the car for the first time yesterday and I noticed right when I hit 5,000 rpms the oil pressure dropped slightly (maybe 3-7psi) and then at around 6,000 rpm shot back up to normal all the way to 6,400 where the tranny shifts. Is the sending unit going bad or is my motor going bye bye? Oil pressure is completely normal every other rpm range and at idle except between 5k-6k it drops slightly. Thanks!
Jeff
Old May 3, 2003 | 03:37 PM
FastZinTennessee's Avatar
Mine drops in second gear pulls in the mid RPM range down to 20psi, then comes back up. Nobody here seems to know what is wrong, but some others have the same thing happen. I wouldn't worry about it. If it runs good, doesn't knock, or make any odd noises I would forgedaboutit!!
HectorM52
Jul 30, 2017 11:46 AM
edman
Jan 22, 2015 02:45 PM
Jessie4tin
Jan 7, 2015 08:53 AM
jayblev95
Dec 1, 2014 06:55 AM
Jul 4, 2005 05:00 PM
