why does my graph have a loop in it?
Old Nov 13, 2004 | 04:10 PM
Tibbys96Z's Avatar
Let me know what you think, I'm trying to fix the crazy loop in the graph. It revs to about 5k then goes down to about 4600 and back up strong again. This is a fresh rebuild, and the first tune from madz28 (two thumbs up for Ion!). It has a 3k stall, heads/cam, 30lb svo's....
http://memimage.cardomain.net/member...64_55_full.jpg
Old Nov 13, 2004 | 04:45 PM
LWillmann's Avatar
Re: why does my graph have a loop in it?
Converter lockup will cause a drop in RPMs and be shown on a dyno graph as a loop.
Old Nov 13, 2004 | 06:44 PM
Tibbys96Z's Avatar
It is happening at about 5k rpms though..? After my car dyno'd I watched about 6 other auto cars and none of theirs did that.
Is my converter not locking up properly?
Old Nov 13, 2004 | 06:51 PM
LT1Squirrel's Avatar
wtf......
Old Nov 13, 2004 | 06:53 PM
Tibbys96Z's Avatar
Originally Posted by LT1Squirrel
wtf......
exactly!
Old Nov 13, 2004 | 07:28 PM
LWillmann's Avatar
I have seen some Auto cars lock-up on the dyno, but not others. Has your car been tuned by anyone or are you running the stock tune?
Old Nov 13, 2004 | 08:04 PM
Tibbys96Z's Avatar
madz28 did the tune. I have an e-mail in to him to see what he thinks.
Old Nov 13, 2004 | 08:18 PM
LWillmann's Avatar
Do you have LT1 Edit, or did he tune the PCM and ship it to you? If you have LT1 Edit, you could look at the TCC apply settings to see what the lock-up characteristics are at WOT in 3rd and 4th gear.
If he shipped the PCM to you already done, he'd have to look at it.
Old Nov 13, 2004 | 08:41 PM
madwolf's Avatar
Stock 3rd gear lockup point is 95 MPH and I didn't change that on this particular tune. If I had to guess, it's a dyno glitch (unless you have 2 graphs from 2 different runs with the exact same problem) or this is just how this particular dyno reacted to his converter lockup.
Old Nov 13, 2004 | 09:42 PM
Tibbys96Z's Avatar
This is one of three pulls. All three had the loop in it..
I just want to be sure it isn't a mechanical problem.
Thanks everyone
Old Nov 14, 2004 | 11:06 AM
funina91ss's Avatar
I had to push on the break alittle so mine wouldn't lock up.
Old Nov 14, 2004 | 03:15 PM
Tibbys96Z's Avatar
what stall/converter was it? If you remember what rpm and mph was it. This is a 3k stall and it is acting up at 5k rpm. I'm not sure what mph this was happening at, unfortunatly, the computer didn't show that.
ImNraged
Aug 19, 2018 08:02 PM
93 RedBird
Nov 15, 2015 08:24 AM
tommalcolm
Sep 11, 2015 03:39 PM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
