why does the intake/throtle body get so dirty inside?
Old Mar 14, 2004 | 07:19 PM
Xride's Avatar
Why does it look at dirty and oily inside the throtle body and into the intake manifold when you take off the elbow?
On higher milage cars I mean.
Old Mar 14, 2004 | 07:24 PM
Spinner's Avatar
Happens to any car ever made with a PCV system.
The system vents the extra pressure from the crankcase into your throttle body. The vent line has baffles in it to keep oil out, but they don't catch 100% of it, so a film of oil that got through the lines builds up inside.
Old Mar 14, 2004 | 07:31 PM
Xride's Avatar
how often should it be cleaned? seems like that gunk in there cant be good.
and is there a way to prevent it? or is that bad?
Old Mar 14, 2004 | 07:38 PM
Spinner's Avatar
There's no real way to prevent it, minus removing the PCV system, which would be silly. Once a year is fine to clean it, it doesn't generally cause problems.
Old Mar 14, 2004 | 07:41 PM
dnlFF's Avatar
it is just combustion and that is normal for just about any car these days. run higher octane fuels. Also, run seafoam or G.M combustion cleaner and you will see a big difference in fuel managment.
carl.froehlich
Mar 13, 2015 12:38 AM
CARiD
Feb 9, 2015 09:35 AM
Sandersen511
Jan 13, 2015 03:49 PM
Queens94z28
Dec 20, 2014 09:11 PM
squarehead
Nov 21, 2014 08:02 PM
