why do the stock pistons have a nipple
Old 02-16-2003, 01:47 AM
D James's Avatar
I was just going through my chiltons manual and noticed the pictures of the stock pistons, and in the middle of the dish is a nipple with a small hole. I've seen this before with other stock pistons, but I'm not sure of its purpose, is it from the manufacturing process?
D James is offline
Old 02-16-2003, 08:56 AM
shocktrp's Avatar
Here's a pic of a blown motor with stock pistons (not mine). No nipple on them.
http://www.worldisround.com/photos/369/161.jpg
shocktrp is offline
Old 02-16-2003, 09:09 AM
Rodrigues's Avatar
I just looked at my stock pistons yesterday and I didn't notice a nippe. It does has 4 small dishes to clear the valves it looks like though.
Rodrigues is offline
Old 02-16-2003, 09:58 AM
madwolf's Avatar
Here's a picture of the stock pistons.... no "nipples"...
madwolf is offline
Old 02-16-2003, 10:30 AM
joeSS97's Avatar
I like nipples.
joeSS97 is offline
Old 02-16-2003, 10:52 AM
Don 97 SS's Avatar
Yep, dems the one's! They look more like two butt cheeks than nipples to me. I think he was reading a girlie magazine before he checked out the Chiltons pics. BTW, shop manuals are notorious for slipping in pics of other "similar" parts.
Don 97 SS is offline
Old 02-16-2003, 02:22 PM
D James's Avatar
I haven't torn down the engine yet, but in my chiltons manual it shows some photos with a nipple in the middle, I've seen them before on my Buick 455, as well as Olds 455, so they must be common. I see the pictures you guys posted do not look like the pictures in the chilton, so maybe they took them of the V6. At any rate I still can't figure out the pupose, I would thnk it would cause more bad than good since its a good spot for detontation to occur
D James is offline
Old 02-16-2003, 03:17 PM
KillinFormula's Avatar
mad wolf, what year is that LT1, because the antifreeze in it is regular, not dexcool, just wondering, sorry if it is off topic.
KillinFormula is offline
Old 02-16-2003, 03:27 PM
Mtrhds94Z's Avatar
shocktrp's pic has the antifreeze showing[ also they aren't stock pistons, either..]
madwolf's pic they are stock pistons [I don't see any antifreeze tho..
The 'nipple' might be from 'centrifugally cast' pistons, or from a casting sprue..
Many of us use regular antifreeze also...
Mtrhds94Z is offline
Old 02-16-2003, 03:41 PM
PNYKILR's Avatar
Location: Albuquerque,NM--5,600 feet above you sea-level cats
That looks like a flat top piston to me. Those are not stock LT1 pistons.
now those look like stock pistons.
PNYKILR is offline
Old 02-16-2003, 03:45 PM
Dr.Mudge's Avatar
Yep, Madwolf posted stock pistons, the others aren't. They have 7cc valve reliefs, but no nipples, the Chiltons sometimes shows other cars, but I dont recall any nipples in my Chiltons(?)
Dr.Mudge is offline
Old 02-16-2003, 03:49 PM
In madwolfs pic.... you can see i think 3 holes with green antifreeze in there. 96 and up are reqired to use DEXCOOL. i think other years can just use regular.
Old 02-16-2003, 05:29 PM
Dr.Mudge's Avatar
Required why? If you switch all you have to do is get all the Dexcool out of there by flushing the system.
Dr.Mudge is offline
Old 02-16-2003, 05:32 PM
Greasepunk's Avatar
95's came with Dex-Cool, and it's not really "required" it's just that GM thought it to be a better deal since it supposedly lasts 5 years...
Anyone got P/N's or suggestions for replacement upgraded pistons for LT1's? Something you can use with stock setup or maybe a combo of all the stuff to change with pistons?
Greasepunk is offline
madwolf's Avatar
The engine I posted a picture of is a '95. Yes, the antifreeze is green. Like Dr.Mudge said... if you flush it all out who cares what you use afterwards? As long as you don't mix...
madwolf is offline
Quick Reply: why do the stock pistons have a nipple
