Why aren't Ported and Polished heads actually Polished?
Old Dec 12, 2006 | 11:31 PM
Wild1's Avatar
I've seen a lot of pictures of Ported and Polished heads but the surface finish seems to be somewhat rough... almost like bead-blasted. Shouldn't they be polished like a mirror? Or is the rough surface to aide turbulance?
Old Dec 12, 2006 | 11:36 PM
seawolf06's Avatar
Yes, the rough surface you see is meant to enhance the mixture of the air and fuel. The polished portion is actually the chamber. Most people don't post pics of that since they're mostly the same, but check out the thread in the advanced tech section on grooves in heads and you'll see a couple pics. The chambers are polished to resist buildup of carbon and such. Someone feel free to correct me if I'm wrong.
Old Dec 12, 2006 | 11:41 PM
Kevin97ss's Avatar
You would want to see the exhaust port polished as well.
Kevin
Old Dec 12, 2006 | 11:42 PM
Wild1's Avatar
Doesn't carbon build up in the ports too? If the ports were at a mirror like finish, it would seem that they would also resist carbon build up.
I'll check up on that article in the Advanced Section... thanks for the tip.
Old Dec 13, 2006 | 12:00 AM
seawolf06's Avatar
The exhaust ports are usually pretty smooth, but never the intake. The intake valve is closed when all the combustion/carbon is going on, excluding the overlap period.
Old Dec 13, 2006 | 04:17 PM
Wild1's Avatar
There's got to be carbon in the intake since carbon can build up on the valves, manifold, and Throttle Body. About every 6 months I wipe down my TB. So, if the intake port was polished, then it would seem there would be less tendency for carbon build-up.
This is only a guess.
Old Dec 13, 2006 | 08:04 PM
SS RRR's Avatar
you have serious problems if you are getting carbon buildup in your plenum, intake runners, intake ports or intake valves.
Old Dec 13, 2006 | 10:10 PM
T/A-Bob's Avatar
In the "old days," the ports and the combustion chambers were polished... since then (I believe) the thinking has changed regarding high-speed air flow across a surface like that... ?? Maybe the old terminology of "polished" has hung on... ??
Old Dec 13, 2006 | 11:48 PM
seawolf06's Avatar
I think that's more likely oil coming from your pcv valve. You should definitely get that checked because it should not be necessary to clean it that often.
Old Dec 14, 2006 | 11:21 AM
Wild1's Avatar
It could be the EGR / PCV. My last smog check was at the limit with NOx.
Old Dec 14, 2006 | 12:20 PM
87lt1rx7's Avatar
I believe the other reason for polishing the combustion chambers is to reduce hot spots and detonation. i am sure this is mainly with older small blocks with cast iron heads more than newer aluminum.
Old Dec 14, 2006 | 09:45 PM
Wild1's Avatar
Now that you bring that up, I do recall reading about polishing the combustion chamber and piston heads. It was an article about "reflective heat". The point is to put more energy back into the combustion chamber for a more complete burn.
oldschool
Feb 9, 2016 09:21 PM
Dmonty
Jun 2, 2015 11:19 PM
jj_burchiel
Mar 5, 2015 07:05 AM
Roadie
Feb 16, 2015 10:34 AM
