why is 95 opti better
Old May 8, 2003 | 08:49 PM
oaklandz28's Avatar
i dont understand why the 95 opti is better than the 94 opti. can some one explain why.
Old May 8, 2003 | 08:51 PM
norcalstreet's Avatar
They include vacuum lines which suck the moisture out. Whether it's "better" is debatable. It may help prevent gradual wear but if the water pump dumps water on the opti it'll blow up just the same as a 93-94 opti.
Old May 8, 2003 | 08:52 PM
oaklandz28's Avatar
so if i was to replace my opti other than that there would be any difference? No power gains?
Old May 8, 2003 | 08:55 PM
No gains at all. Frankly, there's almost nothing you can do to your ignition system to make gains. Focus on induction and exhaust first. An aftermarket ignition isn't really needed until your dealing with supercharging or N20.
Old May 8, 2003 | 08:56 PM
turbo_Z's Avatar
there is no performance gain from going to a vented opti.. it just has a vent.. that the only difference. a vent will only prolong its life by flushing out water and water vapor if the opti ever gets wet.
Old May 8, 2003 | 09:00 PM
oaklandz28's Avatar
i was just asking because im going to replace mine soon and i wanted to know would keeping the 94 opti would be the same as going to the 95 vented.
Old May 8, 2003 | 09:28 PM
Blue89Bird's Avatar
you can't just replace the opti with a 95+ one, there are quite a few other things that need to be replaced such as wiring harness, vacuum lines, cam dowel, etc.
Old May 8, 2003 | 09:36 PM
oaklandz28's Avatar
is there a guide or a website that can help me replace my old 94 opti with a new 94 opti? all the ones i see is for the vented opti.
Old May 8, 2003 | 09:42 PM
Blue89Bird's Avatar
same thing, just disregard plugging in the vent tubes.
Old May 8, 2003 | 09:43 PM
oaklandz28's Avatar
so it is easy as taking old off putting new on?
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
