who's got UNcoated headers???
Old Apr 15, 2004 | 09:09 AM
ppmz28's Avatar
So, who has uncoated headers??? Have you ever had any probs. since they are uncoated???? I know that they will rust and junk but will they cause any other probs. I have heat resistant wires going in so that isn't much of a prob. as long as they don't touch. thanks
Old Apr 15, 2004 | 09:16 AM
Showme's Avatar
Hey,
I've got SLP non-coated 1 3/4" shortie headers. They are stainless steel and have NO signs of rust. These header (on my car) does not leak whatsoever. Plug access is a PITA as you probably already know.
Email me at badja2@msn.com
for more info.
Tim
Old Apr 15, 2004 | 09:19 AM
ppmz28's Avatar
wow, how long have you had them on??? do you know if pacesetters are stainless??? I have no clue.
Old Apr 15, 2004 | 09:42 AM
Kryckter's Avatar
I have hooker's non-coated, They have no signs of rust and they have been in all weather coniditons for 6 months now. Still working great and looking fine!
Old Apr 15, 2004 | 09:55 AM
Brent94Z's Avatar
Super Moderator
I think a lot depends on where you live as to how well they will hold up. I live in Florida and had MAC uncoated headers on my 94Z for like 5 years. Here is what they looked like when they were coming off...
http://www.bfranker.badz28.com/fbody/exh-0654_IMG.JPG
http://www.bfranker.badz28.com/fbody/exh-0653_IMG.JPG
http://www.bfranker.badz28.com/fbody/exh-0658_IMG.JPG
http://www.bfranker.badz28.com/fbody/exh-0665_IMG.JPG
Not NEW looking but not bad either for 5 years
Old Apr 15, 2004 | 10:45 AM
CANTONRACER's Avatar
I will never buy headers again unless they are coated.
Old Apr 15, 2004 | 11:00 AM
BlakeW5's Avatar
CANTONRACER I will never buy headers again unless they are coated
Why's that? I've been debating the issue for a while now. I've been thinking about uncoated to save money (don't really care how they end up looking). I figure if people haven't had any problems with them it shouldn't be that big of a deal.
Old Apr 15, 2004 | 11:04 AM
Steve0's Avatar
I do.
I've got uncoated macst. I got them used, 2 years old and they looked pretty good. A fresh coat of paint was applied and we'll see how long they hold up. I've only had them about a month so far.
Like Brent said, I think it depends on where you live how well the headers will hold up. My dad has spray can coated headers on his '55, which have been installed for oh... 15 years now. The car is garaged and driven once or twice a week They barely have any rust on them at all.
Old Apr 15, 2004 | 11:10 AM
GreenDemon's Avatar
People in northern climates will most likely have more problems with uncoated because of salt on the road for several months out of the year.
If you live in the desert they should last forever.
There's a lot of other metal under the hood and it doesn't corrode that fast, the main reason for coated is to keep heat out from under the hood. Of course the stock manifolds aren't coated, so if you can keep your wires from touching the headers you should be allright. If you want them to look pretty you can always get some chrome ones, summit sells chrome bbks w/ y-pipe for less than $400.
Old Apr 15, 2004 | 11:11 AM
ppmz28's Avatar
I live in SC so we have very high humidity. would that cause a problem??? Mine are black and sprayed black w/ the thermo-tec high temp paint. How long do you think that color will hold up??? thanks
Old Apr 15, 2004 | 11:16 AM
schpenxel's Avatar
http://community.webshots.com/photo/...24760079utRseV
There's mine, hardly any time really on them, I've only had the car running a month or so. Anyways, the paint fell off after like 10 mins of running the car and of course they rust pretty quick after that.
Old Apr 15, 2004 | 11:18 AM
GreenDemon's Avatar
I haven't heard of anyone ever having the paint last that long, but I guess you can find out.
The humidity shouldn't be too much of a problem, most rust is from liquid water getting to things. They might not look perfect but if that's not your intention they should hold up for quite a while. Just keep an eye out for rust, it's like cancer, once you've got it it spreads quickly and it will come back sooner- gotta get rid of that stuff as soon as you see it.
I think that headers probably abide by the same principles as the rest of the exhaust, as long as you drive it every once in a while and let them get fully heated up it should at least drive the moisture out.
Old Apr 15, 2004 | 11:23 AM
ppmz28's Avatar
So does anyone know if pacesetters are stainless steel?? And, if I am geting rust I need to get it off? How do I go about that? thanks guys
Old Apr 15, 2004 | 11:28 AM
GreenDemon's Avatar
Letting it rust or not is up to you. But if you let it go there's no going back, basically.
You can clean rust off with some high grit sandpaper or possibly rubbing compound depending on how deep it is. If the rust is allover the place there's no point in trying though, you'll just make it easier for the metal underneath to corrode.
Old Apr 15, 2004 | 11:33 AM
ppmz28's Avatar
well they go on tomorrow and they are brand new.... how long do you think it will take for them to rust??? thanks
