whole list of problems
Old May 25, 2005 | 01:31 PM
97silvermaro's Avatar
finally got the swap done and the engine runnin....
95lt1, runnin le3 heads, and le2 cam, 58mm TB, 42lbs inj, stock bottom, madz28 tune.
1. got the motor runnin, but wont idle right. hooked up a scanner and the rpms jump up and down from 500 -1100... itll run like this for a while and then finally cut off.... are the injectors too big for this setup??? also got a DTC 33 map sensor or circuit too high... not sure about that one though... spark is also at like 28 degrees , IAC stays around 100? dont know how to read the scanner but those are some of the numbers
2. the rpms are wrong accordin to the guage... i have a 98z28 cluster... ill setthe throttle to an exact rpm ex. 1000 rpm and take off the needle and put it on a 1000rpms... the tach will read a 1000rpms everytime the scanner does but no other rpm is correct accordin to the guage ex. scanner 1500, guage 2300???
3. fuel guage reads full always.... i put the 95 sending unit in too...
thanks
Old May 25, 2005 | 01:36 PM
MeanGreen97Z's Avatar
Re: whole list of problems
Does the car run right now? You said it shut off but I wanna know if it will start again. Double check the connection of the TPS. Can you get a data log of the car while it is flutuating rpm?
Old May 25, 2005 | 02:10 PM
1racerdude's Avatar
Did you have the fuel pressure right? If the idle is going up and down your timing will be all over the place. Your fuel guage has no connection.42's require a tune.
Old May 25, 2005 | 04:40 PM
Compstall's Avatar
I would think that 30 pounders would be more than sufficient for where you're at. 42 lb injectors are in the forced induction territory.
Old May 25, 2005 | 10:31 PM
thats what i figured... yes itll restart but same ole same... it does act like its gettin too much fuel
Old May 25, 2005 | 10:39 PM
OBE1 95Z28's Avatar
Double check for vacuum leaks. Might also want to clean your MAF.
Old May 25, 2005 | 11:08 PM
Compstall's Avatar
You should get on the LT1_edit mailing list and ask around there.
Old May 26, 2005 | 01:01 PM
whats the mailing list?
Old May 26, 2005 | 09:07 PM
Compstall's Avatar
http://www.lt1edit.com/
Jan 23, 2015 01:13 PM
Jazsun
Dec 29, 2014 12:14 PM
Dec 5, 2014 11:42 AM
siguy
Nov 27, 2014 10:07 AM
