Who uses, or knows of anyone using a monoblade throttle body?
Old Aug 22, 2006 | 01:07 AM
Built LT1's Avatar
I am concerned about maximizing my LT4 manifold in my street strip 383. I currently have a BBK 58 mm and wonder if I need something bigger to support my heads and cam; a thread many of you have already read. I also use a TNT N20 plate system. I am sure the two nozzles restrict flow to a measurable degree and thought a monoblade with it's 1300+ cfm capability would out flow the 58mm WITH the nozzles in place. Will this help performance? I also heard that monoblades are difficult to tune. Any insight is appreciated.
Old Aug 22, 2006 | 01:46 AM
1racerdude's Avatar
Re: Who uses, or knows of anyone using a monoblade throttle body?
I am using one but not on an LT4 intake.
Why should they be harder to tune?
Unless ya are figuring on turning 7/7500 and ya were making 650/700FWHP then ya don't need it.
Old Aug 22, 2006 | 01:59 AM
Built LT1's Avatar
The tuning question is exactly what I am tying to ascertain. I have heard that porting through the Idle Air Control on the manifold can cause tuning issues. I figure if my new motor is nearing 7000 rpm and has two N20 nozzles restricting flow at the intake, a monoblade would alleviate both issues. I would like to run it but only if it does not cause adversive tuning issues/problems.
Old Aug 22, 2006 | 02:13 AM
1racerdude's Avatar
Don't use the IAC. Do it just like a carb and use the blade screw.
Old Aug 22, 2006 | 05:28 PM
Built LT1's Avatar
Bump,
Does anyone have an informed opinion about this monoblade?
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
