Who sells AS&M headers?
Old Mar 2, 2004 | 06:08 PM
RedRyder518's Avatar
Cool Who sells AS&M headers?
Been looking around and I did a search over the internet and I really can't find anyone that sells them other then AS&M themselves. Anyone know where I can find them for a good price?
Old Mar 2, 2004 | 06:13 PM
Bersaglieri's Avatar
Check most of our vendors do, www.thunderracing.com etc.
-Dustin-
Old Mar 2, 2004 | 06:15 PM
Although I learned that its prolly best just to get them from AS&M. You eliminate the middleman problem.
-Dustin-
Old Mar 2, 2004 | 06:22 PM
Should I want, would I be able to use the '94-'95 set for my '96 and use an offroad pipe?
Old Mar 2, 2004 | 06:25 PM
Yes, you just need to convert it to a 94-95 style with an s-pipe, you can ran a cat or ORP with that set up.
-Dustin-
Old Mar 2, 2004 | 06:28 PM
CDN WS6's Avatar
If you're planning on ordering a cat-back at the same time there's no need for an s-pipe. Just order a 94-95 style cat-back and an off-road pipe and everything will line up.
Old Mar 2, 2004 | 06:33 PM
Like My Taillights?'s Avatar
i got mine at tbyrne. I forget the exact price but it is actually cheaper than buying them from AS&M directly.
Old Mar 2, 2004 | 06:41 PM
sc93's Avatar
I got mine at tbyrne
Old Mar 2, 2004 | 07:08 PM
I have the SLP 2OTL, so I'm assuming that it will line up.
Old Mar 2, 2004 | 07:48 PM
JeffK's Avatar
I have the "S" pipe on mine since I have the dual high flow cats. You are going to LOVE the way the system sounds with the 2OTL.
Old Mar 2, 2004 | 09:31 PM
It will not line up with the standard AS&M y-pipe if you have a catback made for the 96-97 dual cat setup. You'll need to convert it to the 94-95 stlye with a S-pipe, unless you bought a 94-95 catback or the one you have is already setup for single cat operation. Your other alternative would be to buy a dual cat y-pipe for the AS&M but those are pricey.
-Dustin-
jbrockwell
Mar 14, 2015 08:44 PM
Jlo
Feb 3, 2015 09:41 PM
Moshbmx1
Jan 20, 2015 03:27 PM
