who sells 3/8" diameter 7.2" pushrods?!?!
Old Jul 15, 2005 | 12:01 PM
AlwaysCode390's Avatar
Exclamation who sells 3/8" diameter 7.2" pushrods?!?!
I was looking all through my summit magazine and can only find 5/16 7.2" pushrods. Will the 5/16 be strong enough for use with the 306 cc cam I just bought or should I try my hardest to find the 3/8? Also are those the correct length I need for a stock deck set of heads? The stock pushrods in there are only 10K miles old , will they be just fine? Are stock specs the 5/16 7.2"??? Thanks---
EDIT: I just found some comp cams 3/8, but it doesnt say the length, it just says "standard small block chevy".....uhhhh.....
Old Jul 15, 2005 | 02:48 PM
scyzoryk's Avatar
Re: who sells 3/8" diameter 7.2" pushrods?!?!
You will be fine with 5/16 pushrods...
I have Trick Flow chromemoly 7.200 pushrods wth 0.8 wall thickness for sale...Part # is tfs-21407200...I paid $85 for them They are one of the hardest pushrods you can get...If you are interested email me at sebastianek23@hotmail.com
Sebastian
Old Jul 16, 2005 | 10:35 PM
arnie's Avatar
You want the hardest, or the stiffest?
Old Jul 17, 2005 | 02:05 AM
Lightbulb Re: who sells 3/8" diameter 7.2" pushrods?!?!
Are you trying to clue me into something, lol?! Are the t.flow ones good?! Thanks-
Old Jul 17, 2005 | 07:40 AM
arnie's Avatar
I"m attempting to determine whether the guy worded it that way intentionally, or if he doesn't know the difference between a hard (heat treated) or a stiff PR. A hard rod doesn't necessarily mean a stiff rod, AFAIC.
Yes, the PR needs to be heat treated to withstand contact with the guide plate, but in the end, I want the stiffest PR. The one with the least flex. No, not stating the rods are good OR bad.
Old Jul 18, 2005 | 01:14 AM
SStrokerAce's Avatar
Pushrods aren't always the most glamourous parts on a motor, but they sure can make a big difference. "cheap" pushrods I have found are that way for a reason, one reason why at minimum I suggest the Comp Hi-Tech 5/16 pushrods.
BTW if you want a 7.200" long 3/8 PR check out Smith Brothers or Manton, Comps 3/8 PR's only go as short as 7.500"
Bret
Old Jul 18, 2005 | 01:41 AM
Thanks guys, I just bought the Trick Flow 7.2" 5/16th ones off the guy that posted in this thread. I am sure they will be good enough, I am not going too radical with the engine. I appreciate it---
HarleyZ28
Oct 5, 2015 06:23 AM
OTL
May 26, 2015 09:34 PM
detroit1994z28
May 14, 2015 12:09 AM
94Z28LS1toLT1
May 6, 2015 01:21 PM
Jlo
Feb 3, 2015 09:41 PM
