who said TB Bypass was easy??
Old Mar 27, 2004 | 03:42 PM
SSnakeEater's Avatar
its the two tubes on the bottom of each side of the throttle body right? i got the one on the drivers side off.
but how the hell do you get the passengers side off!?!?!?!? seems impossible
and what is that bigger tube on the upper left hand of the TB going to the valve cover? is that PCV???
Old Mar 27, 2004 | 07:02 PM
Red96Lt1's Avatar
Have you taken the alternator off yet? It helps to get that bracket out of the way.
Old Mar 27, 2004 | 07:33 PM
showen04's Avatar
I just did my bypass today. it really wasn't that difficult other then that tube on the passenger side. what i did was cut the tubing with a razor about an inch down and then pull it off after moving the clip about 1 1/2 inches down the tubing. You will still have plenty of hose leftover after the cutting. Also it is a lot easier if you remove the throttle body itself and unplugg that tube going to the valve cover at the valve cover so you have more room and better abgles to work with.
Old Mar 27, 2004 | 08:34 PM
Eliminator's Avatar
I couldnt get mine off easy either so I cut it then finished the job. took no longer the a few min.
Old Mar 27, 2004 | 09:14 PM
sabre81's Avatar
take off the throttle body. Its extremely easy. while you have the tb off, clean it. its probably filthy.
Old Apr 2, 2004 | 02:09 PM
alright!
i finally got it done. i ended up cutting the tube and running it to the other side. i left the rest of the tube with the clamp still hanging off the little spout on the TB - without plugging it up! do you think alot of unfiltered air will get into the engine? should i still go back and try to plug that up somehow?
Old Apr 2, 2004 | 02:26 PM
ibanez6rg's Avatar
I think you'll be fine, nothing will get into your motor through those holes.
Old Apr 2, 2004 | 08:16 PM
Bud M's Avatar
I'll try to say this as nice as I can. If you don't want to screw anyting up, you really should try to have a better grasp of exactly what you are doing before you start modifying your car. Those fittings are on the throttle body are for a coolant passage. No air will pass through them into your engine. The idea that you started cutting hoses off your engine without understanding what they are indicates that you need to learn more about how things work before you start changing them.
Old Apr 2, 2004 | 08:24 PM
96speedlt1's Avatar
I agree.......look no real harm with come from leaving it exposed(open)but, if you're going to do mods like this, figuring out that getting a bypass cap and a spring clamp to close it off are the first things that should go through your mind.
Old Apr 2, 2004 | 08:31 PM
"White Knight"'s Avatar
Put a K&N on those hoses Then you air will be filtered like no other.........LMAO...i love a good laugh.
^^^just kidding.......but it was funny.
yea i tried to get that hose off with the trottlebody still on........tried for like 15 min and said F-it and pulled the trottlebody and 2 minutes later it's done.
Old Apr 2, 2004 | 08:34 PM
But in all seriousness you can put little rubber cap things over those......then you won't get dirt in the throttle body.....but that doesn't really matter too much....doesn't get to the engine.....just makes that coolant passage dirty. Think of it this way it's a coolant hose that runs through the throttlbody
Old Apr 2, 2004 | 11:47 PM
i pretty much knew what i was doing. i know the coolant runs through the TB to prevent throttle blade icing. however for some reason i wasnt sure if that meant the coolant went through the air passages or not?> guess i never concidered the TB to be hollow
the reason i just cut it is because i was starting to get fustrated and like three people on this thread told me it was a good idea!
and i already did put a rubber cap on the drivers side. i have the plug for the other side but i guess i dont really need it anyway.
oh and thanks to all of you for making me feel like sh**
Old Apr 2, 2004 | 11:51 PM
stereomandan's Avatar
I cut the hose that went from the passenger side of the throttle body to the pipe. I couldn't get it off. I figure I can order the part again if I ever need it (which I doubt).
Congrats on the install. Did you bleed the coolant system? Not sure if it's necessary with this mod, but I did it just in case.
Dan
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
Fatdog2
Sep 16, 2015 11:04 PM
