Who makes thicker head Gasket!
Re: Who makes thicker head Gasket!
Originally Posted by kmook
As far as I know (which may be incorrect)
GM stocker @ .049
Fel-pro 1074 @ .039
GM Impy @ .029
Mr Gasket 5716 @ .026
GM stocker @ .049
Fel-pro 1074 @ .039
GM Impy @ .029
Thats why I asked for someone to correct me
Man, I sure thought the factory LT1 gasket was .051. Wonder where I got that? HmmmOh well.. I tried
Dave C.
The1074 is not a round bore gasket....it is slightly "D" shaped.
Not sure of the other ones.
I would closely compare the volume of the gasket, not the thickness, if you are trying to correct compression.
No, I'm not trying to correct for compression, just figure it out as close as possible with the exsisting non-cometic gaskets. If the bore of the gasket is 4.125, and the bore of the cylinder is 4.030 then there is a bit of area left (shrouded by cyl head and block as it may be), is still area to be considered for figuring out static compression.
