Who to grind a custom cam???
Old Aug 17, 2004 | 12:04 PM
texasTA's Avatar
I am going from a full exhaust + intake 94 Trans Am to a fully forged 383 with all out ported LT4 heads/intake manifold, fully built a4 with a SY3600 stall, 3.73 gears and little other boltons (valvetrain, suspension, etc...)
My question is I had a 233/239 .569/.577 111lsa Combination Motorsports cam that I was goign to use on stock displacement with these heads unported. Well, I made up my mind I am going all out with this MODFEST.
So, who do I get to do a custom ground camshaft?
How do they know what to grind the cam specs to? Do they just go off the head flow numbers?
Matt
Old Aug 17, 2004 | 12:14 PM
RealQuick's Avatar
Re: Who to grind a custom cam???
Bret Bauer can spec a custom comp. cam for you. he spec'd mine for my blown 383 I am building.
bret@bauer-racing.com
Old Aug 17, 2004 | 12:33 PM
94Zpower's Avatar
Most top cars in thier class are running custom grinds from www.cammotion.com
great product and service!
Old Aug 17, 2004 | 01:38 PM
Mindgame's Avatar
Cam Motion does have a great product along with the service. Glad to see they finally brought that experience to the web.
I know and have used two custom grinders in particular. Both of which have speced cams for some of the top players in the drag and road race arenas. If you're interested, shoot me a PM.
-Mindgame
Old Aug 17, 2004 | 02:05 PM
simple's Avatar
www.flowtechinduction.com
www.elgincams.com
there is this place on the east coast in VA. something like Lethal Carburation or something like that
Old Aug 17, 2004 | 02:25 PM
texasTA's Avatar
Thanks guys. So when I get in touch with these people, they are just going to ask me for my flowsheets, mods and goals? Is there going to be anything else I am going to need?
Thanks again
Old Aug 17, 2004 | 02:44 PM
94Zpower's Avatar
Cam Motion will ask u more than the flow #s inorder to make the best Cam for your application, he will ask you stuff like what gear you have, the collector size of your headers, exaust size, flow #s and more, but I honestly belive from what I have seen that He makes the best cams on the market.
Old Aug 17, 2004 | 02:59 PM
RealQuick's Avatar
Thanks again
Bret will want to know flow numbers, what size exhaust/intake components, rpm range your looking to run in, usage of the car, etc.
Old Aug 17, 2004 | 03:22 PM
texasTA's Avatar
Alright, thanks guys for all yoru help. This is turning into a CRAZY big project. But I am sure it will be more than worth it.
Old Aug 17, 2004 | 03:27 PM
SS MPSTR's Avatar
Phil at AI will spec one for you too.
Old Aug 17, 2004 | 03:37 PM
Birdie2000's Avatar
I have a Cam Motion cam waiting to be fired in my engine now. Seems to be of very high quality, specs are based on much more than just my flow numbers. This cam is completely tailored to my car.
Old Aug 17, 2004 | 05:45 PM
Quick96Z's Avatar
Ed Curtis at FTI is amazing with mustangs, and he is really starting to get a reputation with the LT1 and LS1 crowd.
trav
Old Aug 17, 2004 | 06:02 PM
simple's Avatar
trav
yep
Old Aug 17, 2004 | 06:08 PM
Denny McLain's Avatar
I've probably had Cam Motion do about a half a dozen cams for me. The problem is everytime they did one, it was different. The other kicker is they all made about the same power.
It's been three years since I had one ground by them, I'd think they would be a bit more consistent now that people have figured out their combo's a bit better.
Old Aug 17, 2004 | 07:30 PM
SAR2K's Avatar
Ditto.
CM is located here in Baton Rouge. Great folks to work with.
Steve...
LeftoverChinese
Jan 14, 2024 03:03 PM
Noenav
Mar 1, 2019 07:38 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
super83Z
Jul 11, 2002 10:16 PM
