White Smoke!!
White Smoke!!
I just got my exhaust done because i didnt have it connected at all.
Still some leaks on the headers but i quieted it down a lil bit
On the way home i got on it and poured out white smoke
But when the smoke comes into the car it dosent smell sweet it just smells like fuel, just regular exhaust.
Also alot of black smoke came out too
Does this mean blown head gasket or no?
Re: White Smoke!!
Well, if you have white smoke you are probably running too rich and if you're getting black smoke you are probably burning oil. I obviously don't know the answer since I don't know what condition your bottom end is in, but since you have a 94 with a SC, I wouldn't be surprised that you are getting blow by.JMHO
Re: White Smoke!!
Sounds like a head gasket.. worst case scenario is a cracked block
(happend to me)!
If you have problems starting up it means that the cylinder is fill up with something (gas/oil/coolant). If it does have problems starting and it does eventually start and white smoke pours out you definatly are leaking cooling and its probably your head gasket.
(happend to me)!If you have problems starting up it means that the cylinder is fill up with something (gas/oil/coolant). If it does have problems starting and it does eventually start and white smoke pours out you definatly are leaking cooling and its probably your head gasket.
Re: White Smoke!!
Re: White Smoke!!
I was told :
White smoke - coolant
Black smoke - fuel
Blue smoke - oil
But the white smoke thats coming out dosent smell sweet like coolant. I dunno wut is it i gotta do some more looking in depth tomorrow
Black smoke - fuel
Blue smoke - oil
Re: White Smoke!!
im curious to see this too, i get a little white smoke out of mine when im in it hard at high rpms.. but not losing any coolant and not enough oil to notice between changes *shrug*
Re: White Smoke!!
One or both of the following will give you the answer. Pressure test the coolant system at the radiator with first the engine cold and then at operating temperature.
If that doesn't produce results, break out the leak down tester. Both cold and hot.
I'll put money on bad intake gaskets leaking water into a cylinder which BTW can be seen on the plugs.
jackpawt883
Sep 10, 2015 08:53 PM
