Whistling noise?
Old Feb 18, 2006 | 01:32 PM
94Formula driver's Avatar
Whistling noise?
Ok i have a 94 formula lt1 A4 with 188,000 miles on it. Lately when I have been taking it out for drives. When I start to get up in the high rpms...there seems to be a strong whistling sound..not the motor winding out. It only does it when the motor is a little cold. The motor is running pretty good I guess....Although after it has warmed up. From a dead stop If I step on it it will barley squill the tires...but yet It will take of like a bat out of Hell and will shift out of first between 45 and 50mph....does it sound like my motor is not running strong?
Old Feb 18, 2006 | 02:46 PM
MyShibbyZ28's Avatar
Re: Whistling noise?
If you have good tires, an automatic, and 2.73 than your car is probably fine. My car shifts at 55-60mph. Although I can almost spin through all of first, atleast half ways anyways. The whistling sound might be a gas leak on a manifold???
Old Feb 18, 2006 | 03:37 PM
Stoopalini's Avatar
Whistling noise when cold sounds like an accessory pully bearing. My alternator does this.
Thomas.
Old Feb 18, 2006 | 04:55 PM
sprayedtransam's Avatar
someone installed a turbo while you weren't looking
Old Feb 20, 2006 | 11:02 AM
94Z28/SSw's Avatar
Water pump could possibly be starting to go out. Just a thought.
Old Feb 20, 2006 | 11:24 AM
95firehawk's Avatar
Power steering fluid could be a possibility. Mine does it when its cold out. However that is more of a whine than a whistle. When my altenator was starting to go it would whistle just like a turbo (I would get lots of attention in the tech lanes at the track lol) but it didn't go away once warmed up.
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
GT what?
Jul 14, 2015 10:17 PM
colts0455
Jul 7, 2015 07:19 PM
