While I'm at it
Old Jun 29, 2007 | 09:33 AM
immortalmack's Avatar
While I'm at it
First off, thanks for all the information on here. I have never been down as far as changing heads on a motor and yet I was confident enough to do them.
While I'm at it what else should I chnage while the intake is still off?
Old Jun 29, 2007 | 09:50 AM
ZL1modified's Avatar
how many miles?
might want to consider lifters...
Old Jun 29, 2007 | 01:03 PM
Originally Posted by ZL1modified
how many miles?
It's like 150+. When the guy gave me back my heads he said everything look pretty good. What can I do about the low oil pressure at this point.
Old Jun 29, 2007 | 01:07 PM
if the motors out you could put a new oil pump in... i would def. look into new lifters...
i hear the ls7 lifters work in the lt1's... and they are cheap...
Old Jun 29, 2007 | 02:38 PM
2000GTP's Avatar
If you have the heads off, you might as well throw in a cam and all new valvetrain parts.
Old Jun 29, 2007 | 02:40 PM
Do I have to have the motor out to change the oil pump?
Old Jun 29, 2007 | 02:43 PM
The Engineer's Avatar
Be sure to remove and carefully inspect the oil-pump gear drive assembly. And, install a new GM unit if needed. Yes, to get the pan off the engine must be out.
WD
