wheres my 1/4 and MPH?
Went out to the track today, and netted the best as follows. Mods in Sig.
Temp F. 57
Humidity 87
Absolute Barometer 29.52
RT .199
60 1.78
330' 5.157
660' 7.968
MPH 87.18
1000' 10.39
1/4 12.42
MPH 111.18
Best MPH that night was 111.58. This was on Mickey Thompson ET Street Drag Radials @14psi. The track conditions were not the greatest, and I am still working out some tuning issues, but I still think times should of been a lot better. I was launching at about 3-3.5k because any higher, It would just break the tires loose. Any opinions, suggestions? BTW, I just dynoed 390rwhp, with some tuning, but since then, have deleted the o2's and have not went up for tuning again..
Temp F. 57
Humidity 87
RT .199
60 1.78
330' 5.157
660' 7.968
MPH 87.18
1000' 10.39
1/4 12.42
MPH 111.18
Re: wheres my 1/4 and MPH?
What elevation are you running at?
Can you log your runs?
Have you monitored your fuel psi under a load?
As for weather...It is your Baro psi that really kills performance, not humidity for the most part.
Those are some decenttimes for the conditions. You should be dipping into the 11's after a goodtune...so on that note, get that thing tuned man!!!
if you are going to tune it how are going about it? hypertech programmer? Dyno tune?? My LT1 swap for my third gen is in the works and just studying some options on how to go about tuning this thing...
It really depends on the elevation...
0' elevation would be 507' DA which corrects to 12.36@111.76
500' elevation would be 1127' DA which corrects to 12.27@111.52
1000' elevation would be 1747' DA which corrects to 12.18@113.33
2000' elevation would be 2984' DA which corrects to 11.98@115.09
3000' elevation would be 4220' DA which corrects to 11.76@117.06
5000' elevation would be 6687' DA which corrects to 11.26@121.60
Big differences there.
I had my datamaster with me, but completely forgot that I did, like a goof, so I didnt get a chance to data log anything. As for the elevation, I dont know, but will find that out a.s.a.p Sorry for my ignorance, but what is Barometer? Thanks a lot guys, very much appreciated...God Bless!!!
Searching around I find 15'...I have book at home with every track and specs...see what I can dig up.
That being said...I am going to say looking at your times, your down an easy 75 rwhp...easy.
I have a fuel guage that I simply have running around the wipers that I can see when I jump on it. Fuel psi on the road under a load can be different than a dyno.
yea, the track was overall pretty poor that day. Cold, windy, no track prep. I still need to work out some tuning bugs, but I guess I was expecting a lot more out of the car. I was hoping the car would run some high 11's, but I guess I need to go to the track on a better day.
Yea humidity and warm days will kill your et's n traps...here in jersey I try to stay away from the track in summer...spring and fall is better weather for racing
yo diego, how were other 4th gens running? usually theres the huge *** head wind...
you definatly werent putting 390 to the ground, did it feel the same as the day you drove it to the dyno?
oh and theres only 1 seat left if you want it... one has been a throwing knife/katana sword target
