Where to mount the MSD ???
Old Mar 28, 2006 | 04:50 PM
94-z28camaro's Avatar
Where would the best place be to mount the MSD-6 Box?? ..Thanx
Old Mar 28, 2006 | 05:08 PM
Chopstix's Avatar
Re: Where to mount the MSD ???
same location but not my car
http://www.cardomain.com/member_page...76_38_full.jpg
Old Mar 28, 2006 | 05:12 PM
TRYTOTEST's Avatar
thats where i mounted mine too
Old Mar 28, 2006 | 05:14 PM
2000GTP's Avatar
So did you guys put any heat shielding or anything by the fuel lines, or does the box not create enough heat for it to be an issue?
Old Mar 28, 2006 | 05:24 PM
Did you have to fab up a bracket for The box ?
Old Mar 28, 2006 | 05:29 PM
Chopstix's Avatar
no issues
Old Mar 28, 2006 | 05:30 PM
Chopstix's Avatar
nope
Old Mar 28, 2006 | 05:34 PM
hulettsz28's Avatar
same place I will be mounting mine
Old Mar 28, 2006 | 05:37 PM
TRYTOTEST's Avatar
Take the box lay it on the metal and mark the 4 mounting holes
Take a small 1/4 drill bit i think, drill the 4 holes
Mount the box and screw it down. It dosent give much heat at all.
So you should be fine.
Old Mar 28, 2006 | 09:18 PM
bowtiethunder's Avatar
I couldn't get my hood to shut above the fuse box so I installed mine here:
Old Mar 29, 2006 | 01:49 AM
camarokid24's Avatar
You can mount it in your glovebox. I did. Here is a pick where someone did it that way That way its hidden.
Old Mar 29, 2006 | 09:30 AM
TRYTOTEST's Avatar
hmmm good idea, but it probobly heats up in there dosent in?
Old Mar 29, 2006 | 11:51 AM
Not nearly as bad as under the hood I would suspect.
Old Mar 29, 2006 | 08:58 PM
kirschman's Avatar
here's mine. Moved fuse box under its own mount, fabbed up a metal plate, screwed it to the fuse box bracket, then mounted the MSD box. Painted the plate same color as car too
http://gallery8926.fotopic.net/show_...n.php?id=23663
realistyc
Jul 28, 2015 07:32 PM
88IROC_Z
Jul 22, 2015 11:38 PM
Jul 10, 2015 02:23 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
