where to get a stethoscope(sp?) for rocker adjustments?
Old Jan 24, 2005 | 06:03 PM
97s10ondubs's Avatar
I think this would be a big help for ppl with lt's and loud exhaust, not to mention a big cam. I'm trying to get mine right on my LE2 setup but cant seem to get it right.
Old Jan 24, 2005 | 06:16 PM
LT1Squirrel's Avatar
Re: where to get a stethoscope(sp?) for rocker adjustments?
search the net for a medical supply store
Old Jan 24, 2005 | 06:18 PM
moparman's Avatar
Autozone and Pep Boys have them. You can also order from J. C. Whitney.
Old Jan 24, 2005 | 09:07 PM
tamatt27's Avatar
You might try and use a long screwdriver. Put the flat end on the valve cover and put your ear up against the end of the handle. You'd be surprised how well it works in narrowing down a noise!
Old Jan 24, 2005 | 09:36 PM
dkeers's Avatar
I got mine from Jeg's or Summit (I forget now). It was only like $6.00 and it works great. It is an automotive stethascope, not one like a doctor would use.
Old Jan 25, 2005 | 03:58 AM
MentalCaseOne's Avatar
Checkers has them for about 15 dollars here in Hawaii. Mainland prices should be lower. Make sure they arent damaged.... Mine were.
Marvin
Old Jan 25, 2005 | 04:25 PM
BUBBA's Avatar
The scopes are fine for listening through the valve covers, etc., but why don't you adjust the rockers with the engine off? JMHO
Old Jan 25, 2005 | 05:33 PM
cause i did that the first time but i dont think i did it right
Old Jan 25, 2005 | 10:42 PM
DarinsTA's Avatar
you can also just use a section of radiator hose works great for isolating sounds!
Old Jan 26, 2005 | 12:45 AM
TUFF LT1's Avatar
I've seen them at Sears. You could also use a long screwdriver and stick your ear to the end of it which works just as good. Be careful not to scratch your valve covers though if they are nice.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
Slayer
Aug 17, 2015 03:55 PM
realistyc
Jul 28, 2015 07:32 PM
JCSWS6
Jul 19, 2015 06:47 PM
