Where to get fuel injector retainer clips?
Old May 13, 2005 | 02:30 PM
Myxtreme1's Avatar
Where can I get them from? Is it just a dealer item? Thanks!
Old May 13, 2005 | 11:12 PM
Lt1t56's Avatar
Re: Where to get fuel injector retainer clips?
I would guess they are a dealer item only. Might want to make a post in the parts wanted section, someone probably has some laying around.
Old May 14, 2005 | 01:05 AM
breakmyfootoff's Avatar
I didn't put mine back on cause they were loose and didn't appear to be holding anything, I haven't had any problems plus it makes it easier to clean up the fuel rails.
Old May 18, 2005 | 01:16 PM
Myxtreme1's Avatar
So you are not running any clips at all?
Old May 18, 2005 | 01:55 PM
96speed's Avatar
I don't run any clips on my injectors either.
Ryan
Old May 18, 2005 | 02:35 PM
No clips, between the tight fit and the fact that the fuel rails are held down with bolts on top of the injectors they just didn't seem necessary, and I have yet to have any problems. I was paranoid at first and would check the position of the injectors on a daily basis, but I don't worry about them anymore.
Old May 18, 2005 | 03:22 PM
Myxtreme1's Avatar
Cool! I will give that a shot. Thanks!
Old May 18, 2005 | 05:59 PM
Feenix's Avatar
add another that doesn't use the clips
HectorM52
Jul 30, 2017 11:46 AM
Heathen1
Jan 2, 2016 04:27 PM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
