Where to get bracket that holds Air pump, coil and Ignition module?
Ok, during the process of my engine buildup I destroyed a few parts. The one I need now is the bracket that is used to hold the coil, ignition and air pump to the engine. It kind of resembles the AC delete pulley bracket, but has a few extra studs for the air pump. This is the same bracket that the ignition module and coil bracket also attaches too. Can someone please tell me a part number or a place to purchase one from? Also, if anyone has one for sale that would be great also. Thanks
....my bad. The little bracket the holds the igniton module and coil is fine...but it attaches to the bracket that air pump attahes too. That is the one that broke. No I have not tried any junkyards yet...figured somone from this site might be of better help.
the coil and icm are on a bracket of there own and i don't believe the AIR pump bracket connects to either of them. I have had my air pump and bracket off for years now so i don't really remember. If i have it laying around you can have it for the cost of shipping.
....Shoebox and you are totally correct. I was thinking that the ignition module and coil also attached to it(seemed they were in the way of it when I took it apart)...but I went down and double checked and it doesnt. It is just the AirPump bracket. Let me know if you got one. Thanks
Thanks...but I think I found one off a board member already. If that fall through, then this will be my next place. Ill be sure to mention the boards and such...I always do if I use any reference from here.
squarehead
Nov 21, 2014 08:02 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
