Where to get 4 pin Plug for Opti ?
Where can I get the four pin plug for the top of the opti-spark. Mine is corroded and the dealer wants 100.00 for the harness. All I need is the plug but they don't sell the plug only
Re: Where to get 4 pin Plug for Opti ?
http://web.camaross.com/forums/showt...hreadid=282472
Re: Re: Where to get 4 pin Plug for Opti ?
Originally posted by shoebox
1994? May be your lucky day.
It's for my 95 wich has a vented opti.....is there a difference
Make sure the vacuum harness coming off the opti is in good shape and the one way valve and flow reducer are intact, installed correctly, and functioning right.
My one way valve was installed backwards and I was burning up optis every 300 miles till I figured it out. The plug was corroded bright blue everytime too.
I soaked my connector in water(yup, water) overnight and 99% of the at blue stuff came off. Did this 3 times with the same connector and it worked perfectly.
Just a heads up.
Just a heads up.
Thanks fireman...I bought a new vacuum harness , and the old one wasn't even hooked up.
The plug is so corroded some of the metal is eaten away on the pin sockets.
This car had a multitude of problems Im slowly taking care of since I bought it
Originally posted by lt1Olds
http://www.casperselectronics.com/Me...Category_Code=
Is this what you need?
and yes, that is what he needs
