where is the fuel goin
I have noticed a big difference in fuel. I got thew allmost a tank a day. I fiugred it was the lock up in the trani but of couse it wasnt. So i think i have a fuel leak. Ill turn the car off and about 10-20 mins later i have 0 fuel psi on the gauge. i jacked the car up looked back by the tank for leakes. didnt smell or see any fuel. I cant find it. And the motor is runnin lean. Plugs are white. Anybody please help i am runnin outta $$
Make sure you have gas in the tank.Turn the key to the run position,look under your car.Follow the fuel line all the way around.A bad leak will be obvious.How far do you drive?Is someone siphoning it?
i can drive and watch the gas gauge go down its goin some where but i cant find it
i turned the key and got under the car traced it all out. still nothing. some ppl told me bad injector but i dont know
If it was a bad or leaking injector you would be able to smell it in the exhaust like as if it were flooded. A little leak might not but if our going through a tank a day it aint little. I think Joe SS might be on to something. Spy man, maybe someone is syphoning. Let us know because this is a good one.
there is no way someones is syphoning. the car is in my site all day long. how big is a camaro fuel tank? it might be the gague. its been ackin a little weird. liek when i make right turns the fuel gauges shows all the way empty then when the car str8in out it comes back up
Makes sense with a V Shaped Tank. Maybe you should fill it up all the way and drive to E and see how many gallons it takes to refill. Should be about 12-15 Gallons. Also calculate your gas mileage. Any SES Lights?
nope non. its werid like one trip from here to orlando withc is 200 miles i got there and back on one tanks of gass
now i did it last weekend and the gague said i was empty when i got off the highway
Ooops, not me free gas here
