Where to find an offroad stainless 3 Inch Y pipe for 97 camaro
Old Nov 19, 2003 | 03:42 PM
My 97 Z28's Avatar
Where can I find a 3 inch stainless offroad Y pipe for my car. All I have been able to find is a 2.5 inch pipe, and my exhaust crom the y pipe back is 3 inch. What could I do, or where can I find one? Local exhaust shops aren't good around here and would not be able to custom make one. Help please
Old Nov 19, 2003 | 04:01 PM
97WRAITH's Avatar
Summit racing. part#stw-ca957dcos $299
Old Nov 19, 2003 | 04:09 PM
My 97 Z28's Avatar
Are you sure that is a 3 inch Y pipe, doesn't say there? In summits magazine it shows that part number as a 2.5 inch Y pipe made by stainless works.
Old Nov 19, 2003 | 04:17 PM
97WRAITH's Avatar
I read it again I think your right only the y-pipe for the hooker LT are 3".Sorry
Old Nov 19, 2003 | 06:35 PM
My 97 Z28's Avatar
I think all of them might be 3 inch after researching them now on summitracing. I will order it one of these days and tell ya what i think.
Old Nov 19, 2003 | 06:45 PM
stang_killa94's Avatar
have one custom made
Old Nov 19, 2003 | 09:40 PM
My 97 Z28's Avatar
Like i said, can't get a custom one made.
Old Nov 19, 2003 | 09:56 PM
S.J.S.'s Avatar
Thats what I did. It'l cost you just as much as if you bought one. I was just curious as to why it has to be stainless????
Old Nov 19, 2003 | 10:00 PM
My 97 Z28's Avatar
Rest of the exhaust is stainless, plus, it will last me a lifetime. Looks good too.
Old Nov 19, 2003 | 11:28 PM
Even a semi-decent muffler shop should be able to bend pipes and weld them together. Mine was 150 made and installed and if you want it to last, ceramic coat it or buy that clear stuff that acts like a plastic coating but its clear and heat resistant. As for stainless for the looks?? its gonna be under the car where you can only see it if its on a lift so why do you need "looks" on a y pipe??
Old Nov 20, 2003 | 07:54 AM
My 97 Z28's Avatar
Exhaust shop cannot mandrel bend the pipes, only crease them.
Old Nov 20, 2003 | 04:02 PM
My 97 Z28's Avatar
TTT, goin stainless cuz might as well go all stainless singe the rest of the exhaust is that way. also doesn't rust. lasts longer.
Old Nov 20, 2003 | 04:07 PM
TheHeadFL's Avatar
My Random Technology 2 3/4" aftermarket dual cat 96/97 Y pipe works fine for me. Its aluminized too, and I've had it more than a year now with no complaints. Why do you think you need a 3" Y??? Have you seen the outlet diameter on the manifolds?
Old Nov 20, 2003 | 04:12 PM
My 97 Z28's Avatar
Haven't checked. The stock y pipe is 3 inch, so i figured i might as well put a 3 inch on without cats. Plus, it helps with performance.
Also will bolt right up to my magnaflow system, since its a 3 inch echaust also.
Old Nov 20, 2003 | 04:28 PM
jchevy's Avatar
The stock y-pipe is only 2 1/2. The offroad pipe from summit is 2 3/4 and is mandrel bent tube. I bought it, the fit wasnt the greatest but i got it on and then took it to a muffler shop to get welded up.
It flows well enough with my headers to give me an EGR malfunction code. the car also got about twice as loud.
