Where Does This Wire Go???
Old Apr 14, 2007 | 10:50 PM
ben50520012000's Avatar
Question Where Does This Wire Go???
i colred the wire orange.. with adobe.. im stumped where does this wire go, i think its hot.. the wire looks like a ground.. type wire... but im omost positive its a hot cus it acrked... the wire is located next to the abs brain
thanks
Old Apr 14, 2007 | 10:56 PM
camzaro28's Avatar
It is a ground, there is IIRC a 8mm bolt that attaches them to the body of the car. Should be within inches of where the wires are right now
Old Apr 14, 2007 | 11:03 PM
camzaro28's Avatar
http://img.photobucket.com/albums/v6...o28/ground.jpg
okah but its odd that the wire is about 14 inces long... if it bolts right next to where it came from.....
and it arcs
Old Apr 14, 2007 | 11:05 PM
would this make my car not run?
Old Apr 14, 2007 | 11:07 PM
camzaro28's Avatar
yes
did u look at that link with the picture?
Old Apr 15, 2007 | 01:36 AM
i saw the pic.. one of the ends is allready conected.. to the frame,, and i havent seen a spot for the other end like in your pic...
where does the other end go? what is this wire ment for?
i will take more pics tomarow but the car does start now
Old Apr 15, 2007 | 01:42 AM
heres another pic
Old Apr 15, 2007 | 10:28 AM
Do you have a ground wire connected just behind your LH headlight on top of the radiator support?
Old Apr 15, 2007 | 11:36 AM
96ZCamaro's Avatar
So that is where that wire grounds....I couldnt figure it out putting my engine back in so I just grounded it somwhere else on the body.
Old Apr 15, 2007 | 02:40 PM
JONEZ_Z's Avatar
pretty sure you ground that to the coil stud that holds the coil on.
Old Apr 15, 2007 | 02:48 PM
Mike96z's Avatar
Yes its a ground strap, should go from the frame to the block. my 96 it goes to the block where the coil is.
Old Apr 15, 2007 | 02:50 PM
always faster's Avatar
X2
Old Apr 15, 2007 | 03:12 PM
The ground strap from the frame to the engine is a braided strap. The one in the pic is not.
The wires that ground to the coil stud come out of the harness tubing and are only a few inches long. The OP said his wire was ~14" long.
Old Apr 15, 2007 | 03:41 PM
Mike96z's Avatar
Shoebox maybe thats right but mine is setup this way:
the grounds out of the harness AND THE GROUND STRAP are bolt bolted to the same place, which is the (looking straight at the coil) right side coil stud and it has a nut there, so in total I have 3 grounds there. Including this ground strap, because I noticed, when the car wont start, this ground strap heats up and possibly cathes on fire, happened to me. Replaced it 100 times.
