Where does the grey wire on the MAP sensor go?
I'm taking out my factory engine wiring harness and I traced the grey wire from the MAP sensor back to a loom that goes inside the car..
Any ideas where it goes and what it does?
not too bad of a job though.. that's the only wire that has me confused
thanks
...Brady
thanks
...Brady
Props to shoebox!
It's a 5 volt reference that gets tied to several sensors around the engine compartment. (GM color coded this one)
The one you chased down probably goes into the a/c for the temp sensor.
http://csce.uark.edu/~jgbertr/rb/1995_pcm1.jpg
danielpetty540
Parts Wanted
Jan 6, 2015 04:56 PM
