where does this go?
where does this go?
Obveously it goes on the crank... But it what order?? I cant find it in the book, and i didnt dissasemble the motor to know??
http://sixtyninecamaro.com/images/joel/DSC00396.JPG
Re: where does this go?
got to thinking about it, the shortblock i have here is from a 94 therefore the hub on the crank is not the same size correct? well the car which is a 96 has been coverted to obd1 so i dont even need that piece correct?
thanks for the help,
Joel
Joel
Originally Posted by importeater
If you use the pre-96 hub, you can leave off the reluctor.
93-95=long hub
96-97=short hub (because of the reluctor)
